Question about Panasonic SC-PM17 CD Shelf System
Cd tray will not open, need to get discs out etc
Hi, we have some loan disc's in the system and need to get them out, the cd player will not play, will not open, doesn't work on any of the CD buttons. i have opening the tary loading door and there doesn't seem to be anything jammed to stop the trays from moving. about a week ago, wife complained that she asked for disc 2, it played for a bit then stopped, sellecting again disc 2, it started to play the wrong disc, selecting disc 3, it played what should have been in disc 2. no one had moved the disc's from dc2 to dc3, so seems the system got confused? now we need to get the discs out - how to? would be ideal that we get the cd system playing and working again, but also super important to get the cd's out to reduce fines. thanks for any help!
  • mike coker Jul 14, 2007
    ok have taken apart and put together again, have the cd's out of the system :)
    now, and prior to me 'fixing it' when turned on, and first thing press open cd tray, makes an electronic buzz, like a soft hissing (sick cough)and then just has the digital display like its thinking abobut it but nothing happens.
    other than that tape and radio work fine. any help appreciated. thanks, mike
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
gadget
  • 14 Answers
SOURCE: cd tray jammed
If you turn it off at the mains, wait a few seconds then turn it back on. As soon as you turn the power on, try and press the button for the tray to open. If this dont work, you will have to open up your system and remove this disc yourself. Good luck.
Posted on Sep 22, 2006
ctf1800
  • 4402 Answers
SOURCE: CD's will not play
problem with the machine, it's either not reading the disk which would be a laser or the transverse motor or the mechanism isnt loading fully which could be a belt or a bad gear.
Posted on Dec 03, 2007
zair
  • 82 Answers
SOURCE: when we try to play a disc frpanasonic sa-ak28
CD lens may be defective or just need cleaning.
Posted on Dec 13, 2007
  • 6 Answers
SOURCE: CD Malfunction
HIwaog, two things can be causing your problem, one is your lens may be defective,or two your sp motor maybe defective, try changing them.
Posted on May 01, 2008
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 | managemylife.com
Our cd changer will not open or play and I need the CDs out. Please advise
You need to open your player cover to get your disc ( Please unplug the power prior to do this). The main problem is on your mechanism system that prevent you open / close the disc tray. So please check the motor of your mechanism and its gears for malfunction, then get them fixed before retry your player. Regards
Feb 03, 2011 | Sony Audio Players & Recorders
10 year old stereo system CD changer won't play discs
Dust may not be the entire cause, but without knowing the make and model, anything I list would be pure speculation. Please post the make and model. That should give me enough info to list the probable problems and their solutions.
Thanks,
Dan
Mar 17, 2009 | Audio Players & Recorders
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CAVS DVD 105G having trouble reading super CD-G disc
just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
Jul 09, 2008 | Cavs DVD-105G
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
Cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
Dec 23, 2007 | Durabrand W600 Shelf System
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Panasonic SC-PM17 CD Shelf System Logo
49 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
