Question about Hotpoint Washing Machines
HOW DO I CHANGE THE BELT FOR HOTPOINT ULTIMA TCD970
HOW DO I GET THE BACK COVER OF TO CHANGE THE BELT
fanny
  • 146 Answers
SOURCE: How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Posted on Nov 01, 2007
  • 203 Answers
SOURCE: hotpoint ultima wma75
sounds like the filter is blocked you can take the filter out and clean it and check the hole for lint a sock or a coin etc. if this helps please rate me joe
Posted on Nov 21, 2008
barkencoa
  • 3463 Answers
The filter is located in the sump hose at the rear bottom of the m/c.
You need to remove the large clip that holds the hose on
Access is gained by removing the lower rear panel.
Posted on Nov 26, 2008
  • 1525 Answers
SOURCE: changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Posted on Sep 06, 2009
  • 104 Answers
SOURCE: hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Posted on Jan 28, 2010
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
Hotpoint ultima TCD970 dryer squeaking
hi check rear bearing is not worn push at rear of top of drum inside if you can feel it lift replace bearing or it could be belt wheel check bearing 1st
Mar 02, 2014 | Hotpoint Dryers
Machine flashing f 05 taken back cover off and cleaned hose,still not emptying of water, shall we give up or try something else? hotpoint ultima wf 860
make sure you have checked the pump itself, possibly a hairgrip/nail etc. jamming it. also make sure nothing blocking the actual waste hose itself.
Jun 19, 2011 | Hotpoint Ultima WF860 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint washer - belt keeps coming off.
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Apr 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wd865
call hotpoint and get cover for a fiver a month. I do cause mine breaks down regularly - only 2 years old and had engineer out for this prob amongst many others
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do I reattach/replace the belt that causes the Hotpoint Ultima WF860 to spin?
If you remove the back cover from the machine, you should see a big round pulley which attatches in the centre to the inner drum shaft. Below the drum you should see the motor. The belt goes around the big round pulley and onto the much smaller pulley on the end of the motor shaft.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
