Question about Gateway MX3225 Notebook
Can't Connect to Internet!
I am using Gateway laptop, and I installed a memory chip in the laptop.Tere is 2 slots for memory chip.I can't connect to Internet after doing this.Under Connect to a network window it says ''Windows cannot find any networkds''.I installed a new at&t router use wireless internet in the house .Can anyone help me!!
pratiks19@aol.com
pratik21s@yahoo.com
  • gabysrivera
    gabysrivera May 11, 2010
    if you remove the ram memory it works perfectly?
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
SkyLine Wireless Broadband Gateway (PN8584-1) Router: I do not have the instruction book for this router...
Your main computer should plug directly into the router. Just remember, your other two computers, if they are NOT laptops, have to be WIFI ready (additional hardware). Laptops come with this hardware.
Nov 30, 2017 | Proxim SkyLine Wireless Broadband Gateway...
Gateway laptop, can't connect to internet
Network controller in SouthBridge chip on motherboard needs REFLOW or replacement.
Basically board needs service.
Apr 02, 2009 | Computers & Internet
Want to add memory to Gateway 700x
Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
Visit this link : http://www.simpletech.com/upgrades/gateway/700x/700xddrintelp428ghz/
.................sodeep
Mar 31, 2009 | Gateway 700 X PC Desktop
Memory upgrade not working
It only Accepts two PC–2100 SDRAM memory modules..If both are same then the slot might have some problem...
Jan 29, 2009 | Gateway 450ROG Notebook
Gateway laptop
Try swapping the Memory cards and let me know what happens.
Jan 25, 2009 | Computers & Internet
I add memory to my gateway laptop.
maybe the memory is not compatible... there is a dsgnated memory speed... take it to the experts.. dont try to kill ur laptop..
Jan 25, 2009 | Dell Inspiron E1505 Notebook
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Gateway M-6823 Notebook memory
The only reason for this is your laptop only support up to 1 GIG of RAM or 2 pieces of 512 RAM you can check this link for that specs of this laptop http://support.gateway.com/s/Mobile/2007/Tempest/1014768R/1014768Rsp4.shtml
Hope that helps............
Aug 08, 2008 | Gateway Computers & Internet
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
Computers & Internet Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
