Question about RoadPro 5-in-1 Power Station 12-Volt Rechargeable Air Compressor/Jumps
Require a operating instructions for a 5in 1 swpp5 power station
Require operating instructions
I have a 08 Maserati Quattroporte that has preset channels on my radio how can I change them so I can add Sirius radio which I need to put it on 90.5 as the station to do this please help
Read operating guide , usually found in glovebox with other documents that tell you how to turn lights on and indicator location.
Or do a manual search for required station, then press and hold on say preset button 1 to lock in the station. You may hear a bleep when done successfully or 1 may flash, press 1 again to confirm...
This should lock in your radio station of choice on your desired preset button..
Nov 29, 2016 | Maserati Cars & Trucks
Need buffalo drive station 1.0TB operating instructions
did you look here first.
http://www.buffalo-technology.com/en/support/downloads/
Feb 25, 2012 | Buffalo Technology 1TB DriveStation...
Hunter src plus irrigation panel- Getting a PErr message what is that?
A "P Err" readout means there is an overload in the pump/master valve circuit. A readout of "1 Err" means there is an overload in station No. 1, while "2 Err" means an overload in station No. 2 and so on, depending on the number of total stations being operated by the controller.
An overload occurs when the wiring circuit is requiring more than .56 amps of current. This overload will typically occur when the field wiring or valve solenoid is shorted, or if the field wiring is a smaller gauge than required for the application and/or distance.
Apr 02, 2011 | Garden
I have the swatch cordless II phone with base station however I have lost the instruction manual for the base station and therefore cannot register the handset with the base station. Has anyone got a...
To register a handset with Cordless 2 base: Keep pressing call button [loudspeaker icon] on base for 5sec. then press [right pointing arrow in a diamond] twice. Then 9 0 1 then the system PIN if required. Choose internal number 1 to 6 for this handset and then the designation of the base station A=2, B=5, C=8, D=0, followed by [right pointing arrow in a diamond].
Hope that helps!
Jan 17, 2010 | Lands Phones
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
Jul 01, 2009 | LG Audio Players & Recorders
How do i program the sony cdx-m8800 to save the radio stations?
Manual
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=14979&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals')
Jan 02, 2009 | Sony CDX-M8800 CD Player
HOW DO I INPUT CODE 5423 INTO MY BLAUPUNKT PF3 CAR RADIO
After switching on the set will display 'COD' Pressing any station preset key will display '000'Enter the code via presets 1 - 4 (Pr1 displays 1 or 0 only) and press the station increment key. The set will now operate.
Or use instructions from this link (same).
Regards
Apr 02, 2008 | Car Audio & Video
Casio EX-S500 camera
What is the operating system you are using. Windows XP, 2000 and Me do not require drivers, but anything before this, like Windows 98, requires drivers. Install them from the CD.
See the pages of the manual between 180 and 186 for instructions and troubleshooting steps.
More steps indicating your problem need to be supplied for a more clear answer.
Please don't rate this until I have more information, or the supplied answer above was satisfactory. ThankYa!
Dec 04, 2007 | Casio Exilim EX-S500 Digital Camera
RoadPro 5-in-1 Power Station 12-Volt Rechargeable Air Compressor/Jumps Logo
69 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
