Question about Smeg Kitchen Ranges
Wiring drawing for SMEG K42X Extract motor
What's your problem * I have a customer that has a SMEG K42X chimney extract hood with a damaged motor. I called SMEG who gave me a quote for a replacment fan, I called in to my customer to install the fan to find that the new one had six wires and the existing only had four, some couloirs the same. The wire I have are red, blue, orange,white, black,green yellow. And a long brown wire with a female blade crimp on the end, SMEG will not supply me with the information required so I am looking for a little help.
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
  • 587 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
I have a goldstar DH40 , just bought it at a yard sale -
Give it a good cleaning before you do anything else. If the fins or filter are dirty, you won't get good service from it. Make sure the drain path is open.
Feb 05, 2013 | Goldstar Dehumidifiers
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
I"m looking for a wiring
The closet model number I could find was the BT83Al which is a discontinued model. At teh follwoing site you can download a User Manual and Technical Drawing.
http://www.baumatic.co.uk/bt83al_21_106_550.html
If this is not your model other discontinued models can be found here:
http://www.baumatic.co.uk/cooker_hoods_21_106.html
Current Models:
http://www.baumatic.co.uk/cookerhoods.html
Feb 11, 2011 | Baumatic Microwave Ovens
How easy is installation of a Rangemaster chimney hood?
There is a template supplied for drilling holes in the appropriate places. If it is a large hood over 900mm best to have a friend help you. Most important is to check that the bottom of the hood is at least 750mm above the gas burners. Definately use a qualified eletrician to wire this for you.
Oct 08, 2009 | Rangemaster Kitchen Hood
Where is the windshield wiper motor located on 2002 audi a4?
Bonnet lifted. The wiper motor is on left side at the bottom of windshield (for left hand steering wheel). In order to find out the cause of wipers stopping you can try follows: 1. Carefully extract the wiper arms from their axles (two pieces). In some cases you need to use an extracting tool. Heed of the windscreen !!! 2. Disassemble the plastic covers from the bottom of the windscreen. 3. With the bonnet up you can start the engine, (transmission in "N" or "P" position and parking brake on). Now you must switch on the control lever of the wipers, and go to the engine compartment. If the wiper motor runs let the wiper motor running for a few minutes and switch off. Go to the step 4. If the wiper motor do not runs you must check first the electrical feeding of the motor. It is necessary to unscrew three bolts of the mechanism and disconnect the electrical coupling (difficult assurance). If the electrical feeding is OK you must replace the motor - steps 5, 6, 7. If not you must check electrical connections, the control switch of wipers and electric cables. 4. Now you must check the two bearings of wiper mechanism with your hand. In the most cases the left bearing is out of order (is very hot). This is the most encounter fault of the wipers running at Audi. 5. For have enough space to manipulation the wiper motor together with their mechanism you must extract the plastic cover of the engine computer box, and extract also the box screws. Then you can move slowly the engine computer box, just for a few milimeters. 6. You must disconnect the electrical coupling of the motor (difficult assurance), unscrew three bolts of the mechanism and extract together with the motor. You must move them slowly between windscreen and engine computer box until the wiper motor go out together with the mechanism. This is the most difficult operation! 7. Now you can repair the bearings, replace entire wiper mechanism or replace the wiper motor. It is not very simply, but it works. Heed of the windscreen !!! Refit in reverse order. Please Rate my Response! Thanks!
Aug 19, 2009 | 2004 Audi A4
I am replacing the windshield transmission on a Audi A4 and can't get the Wipers off the transmission. Do I need a special tool?
Sometimes it is neccessary to use a special tool for extract the wiper arm from their axle:
1. Carefully extract the wiper arms from their axles (two pieces). In some cases you need to use an extracting tool. Heed of the windscreen !!! 2. Disassemble the plastic covers from the bottom of the windscreen. 3. It is necessary to unscrew three bolts of the mechanism and disconnect the electrical coupling (difficult assurance). 4. For have enough space to manipulation the wiper motor together with their mechanism you must extract the plastic cover of the engine computer box, and extract also the box screws. Then you can move slowly the engine computer box, just for a few milimeters. 5. You must disconnect the electrical coupling of the motor (difficult assurance), unscrew three bolts of the mechanism and extract together with the motor. You must move them slowly between windscreen and engine computer box until the wiper motor go out together with the mechanism. This is the most difficult operation! 6. Now you can repair the bearings, replace entire wiper mechanism or replace the wiper motor. It is not very simply, but it works. Heed of the windscreen !!! Refit in reverse order. Please Rate my Response! Thanks!
Jul 11, 2009 | 2000 Audi A4
Washing machine Whirlpool #8280867
The motor spins backwards during extract, so you could have a bad motor. Unplug and replug the motor wiring harness to assure a good contact.
A failed transmission can do this as well. Does the motor run while attempting to extract? (bad) Or does it just sit quietly dumb. Will the timer advance anyway? Are there any water or oil leaks? (bad)
The timer mechanism can cause this, too.($)
Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fans are blowing instead of extracting!!!
just wondering what the problem you had was ? as i,ve just fitted a hood and have the exact same problem....
Cheers !
Aug 30, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Kitchen Ranges Logo
59 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
