Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Code 32 when wind blows
Carrier Weathermaker 8000 2 speed:
Sets code 32 when the wind blows.
I have to shut off thermostat, then shut off circuit breaker to furnace.
Then turn circuit breaker back on, then reset thermostat.
Furnace runs until code 32 sets again.
Could set code within 1 minute or 3 hours - depends on wind condition.
New filter has no effect on problem.
Has been going on for last 3 heating seasons.
Furnace is 8 years old and has been serviced for other concerns.
Furnace is in garage.
4 inch flue running 30 degrees upward about 7 feet to vertical flu.
3 inch water heater flu ties in with furnace flu about 5 feet from furnace.
Cap on flu up on roof is open 360 degrees
  • 144 Answers
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Posted on Jan 25, 2009
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier Weathermaker 8000 error code 32
Hi, if its blinking 3 fast and 2 slow and saying the error is the pressure switch, kill the power. Pull the hose loose from the inducer motor to the switch and blow back and forth. You can hear the single pole contact click open and close. Put it back together and try it again. If it continues, check for any leaks in the air lines first, and if not, replace the switch. You would be better off to order one over the Internet.For a temp. fix only, if the switch contacts are welded shut or open, you can bypass this safety by taking a piece of electrical wire with clips on each end, and jump across the 2 wires. Some have 3 just find the 2 that makes it work. Good luck,
Nov 09, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
My Carrier Weathermaker 8000 a few days ago the air began to blow non stop and the burners are not igniting. I am getting Code 33. I did all the resets, unplug control board, switch to air condition...
You need to look at the wiring diagram pasted on the door panel to get a starting point where to look. I suspect a bad pressure switch, jump it out and see if it starts.
Mar 09, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker 8000 furnance flashing code 31 blower comes on for 90 sec .. then shuts off .. then other fan goes on.. don't see any flames or lighting goin on can you help?
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than five minutes,
inducer shuts off for 15 minutes before retry. Check for: - Excessive wind
- Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used) - Restricted vent
If it opens during blower on-delay period, blower will come on for the selected blower
Nov 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 turns off intermittently
You can find what the error code is by looking on the inside of the bloewr panel. If it is still there after all these years there is a code list right around the wiring diagram. If my memory serves me correctly it is a limit problem. But be for sure and check the code sheet.
Feb 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Carrier Weathermaker SXi. Furnance will not turn on. I shut power off and waited ten minutes and tried to restart. Codes flashing are 12, 31, 32, 33, 41, 42. Can this be started in emergency mode?
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Jan 17, 2009 | Heating & Cooling
Thermostat transformer 3amp fuse blows on carrier weathermaker 8000
I have the same problem with my Goodman compressor. I removed the relay so the wires that control the relay on the compressor are open circuit. They are, and the fuse no longer blows. There must be something wrong with the relay. The resistance on the 24 volt coil seems a little low, but it is not a dead short. I thought the wires might be shorted, but removing the relay would not have fixed the blowing fuse if that was the problem.
Jul 30, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
693 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
