Question about ABB Sace Isomax S6d 630 Circuit Breaker Ac-23a
Dial down from 600 to 500 amps
How do i retreive my voice mail messages
hold the #1 down until it dials your voice mail for you, then listen to messages. push 7 to erase one & push 9 to save one after you listen to them. Phone does not come with voice mail set up already, so if this is a new phone for you, you will have to dial 1 & hold button down until it rings & it will walk you through setting it up
Feb 23, 2015 | Tracfone Wireless LG 440G
How do I set the tension on my JANOME 3434D serger?
Begin by setting all 4 dials on "3" which is the default setting on this model (often "5" on other machines). If a beginner, it would be best to thread the machine with four different colour threads according to the colours indicated on the tension dials (yellow, red, blue &green) so that it is easier to see how each thread responds as you adjust the dials. The two lower dials are for the loopers & must be adjusted until the upper & lower loops meet on the cut edge of the fabric - if below the edge: tighten the left dial & loosen the right dial (& visa-versa) just a fraction at a time. The two upper tension dials are for the needles: if too loose, loops form underneath the fabric below each needle, & if too tight the lower threads will show through to the upper side of your fabric where it is pierced by the needle. Good luck!
Jan 18, 2015 | Janome Sewing Machines
Instructions for brinks timer 42-1005
Pull all push tabs up.
Turn dial to current time by grabbing push tabs and turning dial clockwise. This requires considerable force.
Push down tabs for all the time(s) you want the device powered. This timer will only power a device if a tab is down.
Good for 15 amps resistive or 1/3 hp motor (inductive load).
Apr 20, 2012 | TORK Digital Interval Timer Ssa100r-24
Singer 1570
what dial setting do you need? straight stitch or zig zag?
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number 1570
Click search & the page will show what manuals are available
Feb 08, 2012 | Singer Sewing Machines
Everytime I put the pre-sets for the timer, it does'nt keep time. COuld you assist me or provide me with someone who can repair?
I can assist you.
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
The 'pre-sets' are confusing.
Do you mean tabs or trippers?
Tork 8601 is a 60 minute cycle timer.
The dial should make 1 full revolution each 60 minutes.
Trippers or tabs located on dial are pushed up or down to set on-off schedule.
If dial is running slow, then clock motor has gone bad.
If dial is running on time, then trippers are worn down or timer parts are worn down.
Either case when timer stops functioning, buy a new timer for $110.
If the clock motor was available, you'd probably spend $60 for the motor.
http://www.farmerboyag.com/time-clocks/23080024.asp
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Same Intermatic timer is C8865 for $88.35
http://www.amazon.com/Intermatic-C8865-1-Hour-Repeat-20-Amps/dp/B000GHKO8K
Jul 18, 2011 | TORK Variable Cycling Timer 8601
I need ptcl phone lock code 0572520171
Lock Unlock PTCL Code For Mobile & International Calls If you would like to stop making Mobile & International calling from your PTCL do following steps
  1. First call PTCL help line 1236 and ask them to open lock facility(it will take 24 - 48 hrs).
  2. Once facility is available you can lock phone by dialing *33*1234*4# (replace 1234 with your desired password).
  3. To unlock phone dial #33*1234# (Replace 1234 with your password).
By doing this i lock my PTCL mobile & international dialing.
Nov 05, 2010 | Cell Phones
How do I reset time and date
Which system do you have? Below are the Panasonic systems. Be sure you find yours.......
Panasonic XDP 824/1232
All programming is done at ext. 101
1) Press the program button, followed by *#1234
2) Dial 000, then follow the prompts on the LCD
KX-T308, KX-T616
  1. Use phone with intercom number 11. It will change the time for all phones.
  2. Keep handset down and press INTERCOM button.
  3. Dial 77.
  4. Dial the hour, with two digits (e.g. 03 for 3 o'clock).
  5. Dial the minutes, with two digits (e.g. 07 if it is now 7 minutes after the hour).
  6. Dial 0 for AM or 1 for PM.
  7. Press #.
  8. Press SP-PHONE
Panasonic KXT Series Telephone System
Setting the time must be completed from an LCD Display phone at Extension 11, using the telephone keypad. This system type requires "Easa-phone" series or a 7000 series model telephone (the model number is listed on the bottom of the phone) that has one or more small switches located at the rear of the phone. Digital "XDP" phones can not be used on this system type!
To set the time:
  • Lift the handset or press "SP-Phone" button on Extension 11.
  • Dial "77"
  • Enter the hour with 2 digits. (01 through 12)
  • Enter the minute with 2 digits. (00 through 59)
  • Dial (0) for AM or (1) for PM.
  • Press the "#"
  • Wait for confirmation tone. (Instantly after pressing the # button, new time counting will start).
KX-TA624
  1. Use phone with intercom number 101. It will change the time for all phones.
  2. Move MEMORY switch on rear from SET to PROGRAM.
  3. Dial *#1234
  4. Dial 000
  5. Press NEXT ("Sp-phone")
  6. Press Right Arrow ("FWD/DND") four times until you see the time displayed
  7. Change the hour with the keypad
  8. Press Right Arrow ("FWD/DND") to reach the minutes field
  9. Change minutes with the keypad, if necessary
  10. Press AUTO DIAL/STORE
  11. Press HOLD
  12. Move MEMORY switch on rear from PROGRAM to SET.
KX-TAW848
  2. Press PROGRAM (or PAUSE, if you don't have a PROGRAM button.)
  3. Dial programming access code (probably *#1234)
  4. Press NEXT (SP-PHONE, if you are not using the programming template).
  5. You'll see "Date & Time Set" on your phone's display
  6. Press STORE
  7. Press NEXT to see hours and minutes.
  8. Use your keypad to change the hour
  9. Press STORE.
  10. Press HOLD.
  11. Press PROGRAM
KX-T123211D
  1. Use phone with intercom number 101 (probably the receptionist's phone). It will change the time for all phones.
  2. Move MEMORY switch on back of that phone to PROGRAM.
  3. Keep handset down and press 0 on touch-tone dial.
  4. Dial year with two digits (e.g. 97 for 1997).
  5. Dial month with two digits (e.g. 01 for January).
  6. Dial date with two digits (e.g. 03 if today is the third day of the month).
  7. Dial day with one digit (1 for Monday, 2 for Tuesday, 3 for Wednesday, 4 for Thursday, 5 for Friday, 6 for Saturday, 0 for Sunday).
  8. Dial hour with two digits (i.e. 01 for 1 o'clock).
  9. Dial minutes with two digits (i.e. 07 for 7 minutes).
  10. Dial 0 for AM, or 1 for PM
  11. Press either AUTO DIAL/STORE or AUTO/MEMORY, depending on your phone.
  12. Move MEMORY switch on back of phone to SET.
Panasonic DBS 824, 40, 72 & 96
- From the Attendant's display phone.
  1. Press "On/Off"
  2. Press "Prog"
  3. Press " ##"
  4. Press "FF1 key"
  5. Dial 1#, 2#
  6. Dial the time in 24 hr format.
  7. Press #
  8. Press "On/Off"
- From any display phone in the system.
  1. Press "On/Off"
  2. #98 + Password
  3. Press "Prog"
  4. Press " ##"
  5. Press "FF1 key"
  6. Dial 1#, 2#
  7. Dial the time in 24 hr format.
  8. Press #
  9. Press "On/Off"
Panasonic DBS 576 & 576 HD
From any display phone in the system;
  1. Press On/Off
  2. Press "Prog"
  3. Press " * * "
  4. Dial the " Password"
  5. Press "FF8"
  6. Dial 81001
  7. Dial in new time in 24 hr format.
  8. Press Hold and then "On/Off"
Aug 19, 2010 | Panasonic KX-T7731 Corded Phone
Hello, my date is correct but my time is one hour displays as one hour behind. How can i update it? the phone is a Panasonic KX-T7433 Digital super hybrid system
Please follow the steps below to set the time
SETTING THE DATE & TIME:-
With handset down on main phone
Press ‘Program’
Dial ‘**0000’ or ‘**1234’ (system program no)
Dial ‘#000’
Press ‘Next’
Enter the date using the dial pad
Press ‘Next’
Enter the time using the dial pad
Press ’Store’
Press ‘Program
Thanx
Jul 22, 2010 | Panasonic KX-T7433B Corded Phone
ABB Sace Isomax S6d 630 Circuit Breaker Ac-23a Logo
Top ABB Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an ABB Electrical Supply Expert? Answer questions, earn points and help others
