I need a faster card .have 4gb ram and i wish to upgrade my card but compactness of pc limits this
SOURCE: UPGRADE GRAPHICS CARD
Hey,
From the looks of your system, Its a pentium D 915 CPU, with integrated graphics.
From the spec sheets, you should be able to upgrade to even an 8800 series, although that would require you to purchase a higher wattage power supply.
My recommendation is:
if you want graphics grunt for later model games, (i.e shooters like CoD4) the card you need (without needing a new PSU) would be the 8600gt. This is an excellent card and does not require external power.
If you want a cost-effective option, go with the 8500gt or an ati (amd) something equivalent. They arent the fastest cards out, but they will do a better job than the integrated graphics.
Hope that helps,
Sincerely,
mister_apocalypse, aka <<CKS>>DRpyro
and
maxicube, aka 'monsieur'
Tech Support A team
SOURCE: Upgrading graphics card onto gx280 motherboard
You need to find a "PCI Express" video card. Your Motherboard does not have an AGP slot. There are lots of them to choose from. Better to pay more now and get more memory on the video card than to regret the purchase and buy another one. IMHO
SOURCE: Best Graphics Card, RAM for D101GGc
go for the nvidia geforce 8500, your board Support for up to 2 GB of system memory so no 4GB( too bad)
SOURCE: faulty motherboard?
bullnosestep
It is possible that the new (secondhand graphics card) was faulty and sent an incorrect voltage to part of your motherboard (frying it). However in my experiance it is not likely, I have installed and un-installed 100's of video cards over the last 10 years many of them faulty and only on one ocassion did it ever damage the board.
Things to try:
Double check (triple check) that your card is seated properly in the pci-e slot, this is one of the most overlooked things and is one of the most common problems when installing a new video cards. It may be drawing power from the slot but could still be slightly out of line.
Also most new ish psi-e card require an additional power supply direct from the PSU, did you connect this up if needed. (don't know what make the graphics card is so just in case)
Remove the cards and check the slot for dust and dirt, quite often when you remove an old existing card you can dislodge dust/durt from around the slot pushing it into it, thus making a bad connection to the video card. Blow the slot clean with a compressed air cleaner, can should cost £5-£10, don't use vacuum on the motherboard as this can cause extreme levels of static.
Are you sure you didn't knock a component on the motherboard during installation?
If you have tried all these things then you may have a damaged board. You could take it to a repair outlet to check the board over. They would be able to check the voltages etc... and may be able to locate the trouble.
The Pci-e slots can be replaced and re-soldered but it is a very skilled operation, to be fair you would be much better off buying another board. Lets face it, the slot is probably ok, you may have blown something elsewhere on the board.
Hope this helps and let me know if you solve the problem
Bri
SOURCE: Which Graphics card is suitable????
The is no solid answer because there are several factors to take into consideration.
First: Vista does not play games well yet.
It was released too soon and the Game Mfg's have not addressed the issue.
Many, many people are going back to XP OS. Do you know the MB mfg?
I am a Beta tester for a few game companies and for the most part, we use the BFG nVidia Video card. It is a GeForce based chipset. These cards are already Overclocked to their maximum and tested as stable. Lifetime Guarentee as well.
Is you MB a PCI-Express?
No matter what card you get, you still may not get to play the games until MS Vista gets in gear.
