Question about Curtis-Mathis CM27101S TV
Cable hook up on tv is broke. trying to hook cable up to jvc dvd
Trying to hook cable up to jvc dvd player then to tv so can watch tv because cable hook up on tv was broke
Some times you can try tapeing it on (Black tape). Thats what i had to do one time.... It worked.
Posted on Jan 26, 2009
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
Connect jvc dvd to zenith tv
just hooked up with an rca cable from the output jack ( audio/video ) of your dvd recorder then the other end connect to the input jack of the tv. then set your tv at the same time the dvd player to record.
Aug 11, 2012 | JVC DR-MV150B DVD Recorder/VCR
I can play dvds but not vhs. how do i hook it up or program it, etc, so I can watch vhs?
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
Apr 27, 2010 | JVC HR-XVC19S DVD Player/VCR
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Parental lock
i have the same exact problem what i figured out is that i cant watch cable on it but when i hook a vcr to it i can watch movies. but when i hook my dvd player to it the block comes back on. so i hooked my playstation 2 to my vcr and hooked my vcr to the tv and i can watch dvd's that way. thats all i have sorry..
Oct 20, 2008 | JVC AV-27820 27" TV
Help
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Oct 11, 2008 | JVC TH-M45 System
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Curtis-Mathis CM27101S TV Logo
133 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
