Question about Symbol MC9090-G RFID Handheld Barcode Scanner
MC9000 stuck on booting system screen
Unable to boot device as it is stuck on the white screen with ....Booting System.... at the top of the screen
2 Suggested Answers
SOURCE: Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Posted on Dec 10, 2009
Lap top not booting
If you hit F8 just before it boots, there should be a menu that will let you repair or start the system with the last known good configuration. That may help you.
Jan 05, 2014 | Lenovo Computers & Internet
Whenever I turn on my laptop the screen is blank with a white dash mark flashing in the top left corner of the screen. What do I do?
That is the signal that the BIOS no longer finds an operating system installed on the hdd. All you are left to do is to reinstall it. Use the recovery disk that came with it.
Jul 05, 2011 | Acer Aspire 6920 Notebook PC
Booting from the Dell CD that came with my laptop. No good, I never get to the menu. My computer starts booting from the CD, I get the screen where it says 'Windows is loading files' and the white bar....
press F12 at boot time and select to boot the Diagnostics, in there let it run through the diagnostics and see if you get any error codes.
If this is clean then try booting windows into safe mode by pressing F8 as the computer boots up, then select to boot into Safe mode with command prompt and at the command prompt type chkdsk /r let it finish and try booting your system again.
also make sure you are booting the CD by pressing the F12 key at bootup and select the CD/DVD drive as the boot source. You may be inserting a non bootable CD and it just attempts to load the hard disk after. You can tell if this is happening if the CD light is not flickering but the hard disk light is. hard disk light looks like a cylinder on most laptops.
good luck!
Nov 12, 2010 | Dell Studio 1537 Laptop
Blue screen was appearing while booting the system
This is a driver issue, try this. Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 04, 2010 | Dell Latitude D600 Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Unable too logg into the system
sounds like a hard disk issue try booting from the original s install disk . the see if you can reapir the installtion
if it still can recognise the disk you probably have a hard disk problem. Eithe buy or get a techical person to call out and check the hard disk for you.
if you have win xp boot to the cd then choose repair at the first menu , when you get to the dos screen type in
chkdsk /f and let it do what it must to complete.
hope this helps
Jan 02, 2009 | E-Machines Emachine T5026 power supply **...
On boot up screen reads "Loading PBR 2...done"
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
Booting to Operating System
Have you tried booting from CD? Does it still happen? If so, your RAM might be damaged. Or it might be an overheating problem. Check the fan outtake for dust.
Oct 27, 2008 | Dell Vostro 1500 Notebook
Symbol MC9090-G RFID Handheld Barcode Scanner Logo
258 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
