Question about Reddy R60A Utility Heater
PH55 "lawn boy" porta- heater need parts
I need a fuel filter that screws into the tank and both airfilters.
  • franciamone Feb 03, 2009
    Steve, did Portable Heater Parts have what you needed? I checked out their website and it looks as if they don't sell to the general public. I'm also looking for a Lawn-Boy ph55 fuel filter. Frank
  • ShopGrrrl May 11, 2010
    Just wanted to say thanks so much for the 800 #. I needed parts for our Lawn Boy heater, too & tried everywhere but now finally found what I need!
Lawn Boy sent me an 800 number for the company they sold the heater line to.
800-362-6951 portable heater parts. I have not called yet to find out if they will have qhat I need. Will call tomorrow, Tuesday.
Steve
Posted on Jan 27, 2009
It starts with eas but dies seconds later.....why?
you have a fuel problem. fuel tank fuel line collapsing or carburetor needs new needle and seat
May 21, 2016 | Husqvarna 675 hp 21" Honda Rear Bag Push...
I have a johndeere zero 425 ride on lawn mower It starts & runs for about 25mins then stops & wont start . If left for a while it will then start & do the same thing over again
Get a service manual that will guide you on how to check the ignition module, rectifier regulator, ignition and pulsar coils...it'll have the spec readings, capacities, etc. for different components as needed, for DIY repair
Mar 20, 2015 | Garden
Describe your Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower Problem mwer wont start only burns starter fluid
Hi haystackcalh...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Aug 21, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Does the 650 series 190 cc lawn mower have a fule filter & carborator, because mower starts and quits in about 5 secounds, where are these parts located on the motor
The carburetor should be on the right side of the engine, opposite side as the exhaust. Do you have to prime this engine to start it? If so, it is running on the prime and therefore it is not getting fuel into the carburetor or picked up by the main jet. Either way, the carburetor has debris in it and needs to be cleaned out. If the carburetor sits on the fuel tank, change the diaphram while you have it apart.
I hope this helps get you going.
Aug 04, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Replaced spark plug,airfilter, still my lawnmower won't start
Check your fuel filter in the fuel tank, if you have one.
It may need replacement or cleaning.
Also check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
Keep in mind that the float for the carburetor must be level when you go to
carburetor kit.
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Dec 27, 2010 | Poulan Pro 22inch 625 Series Briggs ...
I have a lawn boy ph100 torpedo heater and I need a fuel filter. Where can I get one
Go read my tip which has the website you need plus some other valuble information at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters Let me know what you think.
hardrocko
Thanks for using FixYa
Feb 13, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Jul 06, 2009 | Garden
Reddy R60A Utility Heater Logo
2,642 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
