Question about Belling XOU592 / XOU593 Electric Double Oven
Diplomat adp 0511 grill has no gas or ignition
  • Belling Master
  • 5,323 Answers
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Posted on May 03, 2015
A manual for a diplomat high level oven and grill, model number 200504035 adp0312 please
I'd suggest contacting UK Whitegoods. They still carry spares for the Diplomat line, they may have manuals available for download.
Otherwise, manuals.com
Jan 04, 2017 | Ovens
I have a diplomat 3300 the oven stopped working but the grill still works.what will the problem be?
IS IT GAS OR ELECTRIC? GAS YOU MAY HAVE CLOGED LINES ELECTRIC YOU MAY HAVE A HEAT ELEMENT THAT HAS GONE OUT AND NEEDS TO BE REPLACED. TRY TO FIND A MANUAL ON LINE TYPE IN BRAND NAME ALONG WITH MODLE NUMBER TO SEE IF YOU CAN FIND A MANUAL.
Jan 31, 2015 | Ovens
How do you light the gas grill
I assume outdoor gas grill? If so, turn on gas at tank. There should be a knob that has a lightening bolt or something similar representing ignition. Turn the knob to that diagram and click the igniter till it lights. If you don't have igniter use a long grill lighter. Once that is lit you can turn other knobs that control other rows of gas if so equiped.
May 17, 2014 | Magic Chef Ovens
My oven wont work
If your gas igniter is bad the gas well not turn on .replace the igniter
Nov 09, 2011 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Nov 05, 2008 | Ovens
Belling XOU592 / XOU593 Electric Double Oven Logo
94 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
