Question about Kenmore 22642 Top Load Washer
Bleach Dispenser clogged, washer over filling
I had a family member come and stay with me and clearly, she can't read that the dispenser in the Washing Machine said BLEACH - she filled it with Fabric Softener for about 5 loads.
I thought I'd cleaned it all up, but now I am having a problem with my washer overfilling, even when set on the lowest setting.
Could the two be related and how can I clean the dispenser so that it can be resolved?
  • brandyhagz Jan 25, 2009
    Opps, I posted this in the wrong place. It's a 11029842991 model.
  • 530 Answers
If the unit is over filling this is a completly seperate problem. you have either a bad pressure switch or possibly the hose that goes to the pressure switch either is detached or (i hate to say it) YOU HAVE A MOUSE! tip the washer back and lean it against the wall. but please not all the way on it's back unless you want a different problem. You need to locate the plastic tub look to the right you will see the air dome on the tub there is a hose that connects to this. see if its attached and let me know
Posted on Mar 26, 2009
How to unclog Whirlpool Cabrio Washer Bleach Dispenser Full of Water?
hot water will be safe yes u can remove the dispenser but may be a bit difficult to figure out it should just snap and pull out once disconnecting the hoses
Mar 17, 2015 | Whirlpool Dryers
Kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
Mar 10, 2013 | Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
The bleach and softner dispenser does not work. The liquid softner would still be there at the end of the wash - never dispensed. I took out the dispenser and cleaned it, but no change. When I leave the...
Don't know if this is the answer, but my dispensers stayed filled also. repairman said the water wasn't flowing into the machine quickly enough and therefore not tripping the sensor that told the machine when to disburse the softener and/or bleach. He took the cold watersupply line loose, and the mesh was full of sediment. He said it wasn't necessary to replace the mesh. Sure enough, it started working immediately. He did the same for the hot water line..it wasn't clogged.
Aug 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
My LG Washer 0642h doesn't always dispense the bleach. I notice that the dispenser fills up with water and doesn't empty. I have to empty it in the next wash. The dispenser doesn't appear to be clogged.
If the dispenser comes with a siphon tube, it is always this tube that is clogged. When the dispenser receives water from the machine, it fills up, the water/softener mix starts to go through the tube, at first by just draining because it has sufficient head, and then as the dispenser gets lower, siphon action in the tube takes place. . This tube must be clear for this dispenser to work.
Nov 25, 2009 | LG Washing Machines
Fabric softener/bleach dispenser full of water
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2009 | Kenmore 46462 Front Load Washer
Automatic bleach dispenser fills up with water during fill cycle
May 04, 2009 | Washing Machines
Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Kenmore 22642 Top Load Washer Logo
148 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
