Question about Hotpoint Washing Machines
How do i fit a drum paddle on my hotpoint wmd962 washing machine it fit but i cannot tighten it
barkencoa
  • 3463 Answers
SOURCE: plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Posted on Mar 02, 2009
barkencoa
  • 3463 Answers
SOURCE: drum paddle keeps coming off had machine blocage
Are you sure you have got the correct paddle, as there is more than one version, and also there is a right and wrong way to fit them.
Make sure you push it hard into the locating slots, you should feel it click into place, to be sure it is located properly, lightly pull it, and it should remain in position.
Hope this helps.
Posted on Dec 30, 2009
SOURCE: I have a Hotpoint AQXXF149PM washing machine, and
I have exactly the same problem on my ...129 model. I'm a mechanical engineer and looking at the design it apears that these aren't designed to be replaced. The 90 degree tab looks to be only accessed from the outside of the drum so can only lock the tumbler in place from the factory. It needs to be bent flat to get the paddle on!
I hope someone can prove me wrong??
Posted on Jul 31, 2010
barkencoa
  • 3463 Answers
SOURCE: How do i remove the
Grasp it firmly, and pull it towards you, it should then release.
Posted on Dec 09, 2010
Change hotpoint wmd 962 g uk drum bearing
Hotpoint dont sell the bearing for WMD962 seperately. You have to replace the whole drum unit.
Dec 01, 2012 | Washing Machines
Drum paddle keeps coming off had machine blocage
Hope this helps.
Dec 30, 2009 | Hotpoint Washing Machines
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
