Question about HP P3015 Laser Printer
Bad rfu signature - HP P3015 Laser Printer
Hp 5550 color laser printer display "downld rfu error over parallel port" how can i get a solution? and what is the cause? thanks
RFU = remote firmware upgrade.
Appears like someone tried to upgrade the firmware.
While the firmware was being downloaded, something interrupted the process. For example somebody tried to use the printer, you had a power problem, your internet went down etc, etc.
You are going to have to try the firmware upgrade again.
If you can't get passed the RFU error, you will probably have to get the formatter replaced.
Aug 19, 2011 | HP LaserJet 5550 Printer
Downld file now SEND RFU UPGRADE ON USB DEV PORT
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
Nov 26, 2010 | HP LaserJet 4345mfp Printer
I have a nintendo 64 and i cant figure out how to connect the rfu adapter i have to the tv. i dont know which cords go where.
Most if nto all RFU conenct to the coaxle connection on you tv.
If you have a newer tv monitor many do not have coaxle conenctions anymore only RCA/HDMI/C-RCA if this is the case on your tv you'll need to
#1 get rca wires for your 64 (easy cheaper)
#2 get a rf to rca converter (harder more expensive)
Aug 03, 2010 | Intec RFU Adaptor for PlayStation® 2
Download file now RFU LOAD ERROR
Upgrading Printer Firmware
WILL SOLVE YOUR ISSUE
HP Jetdirect firmware images have an extension of *.dld while the printer
firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
check the document from the hp
Jan 05, 2010 | HP Office Equipment & Supplies
Ran Reg Easy and then Laptop Toshiba Qosmio will not start again. When I use the DVD to reboot and select repair the system goes off checking and doing for some time then returns a box saying ?Windows...
when you used the Reg Easy it wipped out some of your files that are required to boot. You have no choice but to do a complete reinstall. sorry for the bad news
Oct 25, 2009 | Microsoft Windows Vista Ultimate Edition
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Feb 27, 2009 | HP LaserJet 5550 Printer
Printer Froze and Have Download Message
Downld File Now
RFU LOAD ERROR
RESEND RFU OVER
PARALLEL PORT
Aug 13, 2008 | HP LaserJet 5550 Printer
HP LaserJet 4250 Jet Direct Error
have you updated the firmware to the latest version?
Jun 04, 2008 | Computers & Internet
PS1 RFU adaptor
it would usually be where the t.v Ariel lead is plugged unless its a scart,
Apr 09, 2008 | Sony PlayStation (PS) Console
HP P3015 Laser Printer Logo
553 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
