Question about Sony STR-DE825 Receiver
Sony receiver str-da2000
Protection code 11 problem it wont let me turn on the receiver please help me.
  • Whiskey Mac Mar 02, 2008
    protection code 11 problem it wont let me turn on the receiver I have checkd the wiring, and reset the device. IT shows the fault code even when there are no wirs connected!
  • 944 Answers
Here is the link for the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDA2000ES®ion_id=1 Check page 54 for details of the error message - it should disappear if the speakers are connected properly and the unit is switched off and on. Check page 17 for speaker connection details, and ensure they are all correct. Check page 19 for details of the factory reset/memory clearing. Hopefully this will clear the error code and let you set the unit up. Hope this helps, please ask again if no luck :)
Posted on Jul 14, 2007
SOURCE:
No sound fuse replacement
checa el fusible de la are de sonido si no esta malo seguramente se dano el circuito integrado del sonido.
Dec 16, 2013 | Sony STR-DA2000ES Receiver
Protection code 11
Here is the link to the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDA2000ES®ion_id=1 Check page 54 for details of the error message - it should disappear if the speakers are connected properly and the unit is switched off and on. Check page 17 for speaker connection details, and ensure they are all correct. Check page 19 for details of the factory reset/memory clearing. Hopefully this will clear the error code and let you set the unit up. Hope this helps, please ask again if no luck :)
Jul 14, 2007 | Sony STR-DA2000ES Receiver
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
PROTECTION CODE II ERROR PERSISTS EVEN AFTER RESETTING!!! HELP!!!!!!!!!!!!
A protection message indicates a problem with the circuitry and a reset will have no effect. If the message persists after disconnecting all of the speaker wires, then it is likely that the output transistors are shorted. This will cost in the $25-$40 range for parts.
Dan
Apr 02, 2010 | Sony STR-DA2000ES Receiver
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
Apr 10, 2009 | Audio Players & Recorders
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
Protection code 11
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Some Sony equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Sony STR-DE825 Receiver Logo
299 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
