Question about Ricoh Aficio SP 4100N Laser Printer
SC 546 RICOH 4100 - Ricoh Aficio SP 4100N Laser Printer
Ickoajnc
  • 183 Answers
SOURCE: error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
Posted on Jul 11, 2009
  • 11 Answers
SOURCE: I have a ricoh aficio 2035 that reads error sc 546
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Posted on Aug 17, 2009
  • 7 Answers
SOURCE: how i reset error sc 546 on ricoh aficio 4100n
Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu"
Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on.
Posted on Oct 24, 2009
SOURCE: Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Posted on Jan 07, 2010
joel_baleta
  • 155 Answers
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Posted on Jan 26, 2010
How do i reset sc 546 in ricoh 7140
Heating roller thermistor error (side)
The temperature measured by the heating roller thermistor does not reach 0? after 50 sec. and remains over this temperature for 10 readings. • Loose connection of the heating roller thermistor
• Defective heating roller thermistor
clean toner buildup on thermistor.
Feb 23, 2016 | Ricoh Office Equipment & Supplies
I replaced thermistor on ricoh 1018 and still have sc error 546...can't seem to reset it
reset by going into service mode "clear modes (yellow) and 1 0 7 then hold stop for 5 or so seconds -Carl
Jan 27, 2016 | Ricoh Aficio 1013 All-In-One Laser Printer
Ricoh aficio SP4100NL error sc 546
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
    • 1 Press the "Clear Modes" button. This button will be on the main panel.
    • 2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
    • 3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
    • 4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
    • 5 Turn off the main power. The main power button will be located on the side or front of the copier.
    • 6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
Jul 20, 2014 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Je possède un copieur Ricoh 1022 .il est en panne . il affiche SG 546 . Aussitôt j?affiche 107 en appuyant sur le bouton jaune pendant un moment .l?appareil se mit en marche pendant quelques...
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
SC546
sc 546 is fuser fault!check the connection of fuser catridge or try this:turn on machine-enter the servicemenu-open front door-then power on/off-close front door---->this will restart your Ricoh
Apr 06, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
Jan 26, 2010 | Ricoh Aficio 1035 Copier
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Ricoh Aficio SP 4100N Laser Printer Logo
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
