Question about Music
How do i remove the front grille from a peavey sp4 speaker
2 Suggested Answers
  • 5603 Answers
SOURCE: i have a new peavey
This is based on MOST cabinets like this: First look for any small screws which are usually through the grille near the top and bottom that retain the grille. When those are removed, one has to pry the grille out of the grooves at the side by dishing the grill outward at the center so edges come inward. There often is a "U" shaped rubber strip along the edges that will need to be put back on before grille is dished and put back.
Note that SOME speakers have a fuse or a polyfuse to protect them from excessive current. If yours do not, consider puttin in polyfuses to protect them. They are available from Digikey.com.
Calculate the hold current based on the pwer rating and impedance. Take the square root of the rated power of the HF divided by the impedance and choose aa polyfuse that will hold that current and one that will standoff the peak voltage of your amps. Calculate that voltage as the square root of the max power of your amp divided by the LOWEST impedance allowed for the amp.
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=polyfuse
Set the filter to search for "Radial" type package and find suitable rating in the list that comes up.
Posted on Jan 09, 2011
How do I open 1210HS Peavey speaker cabinet?
Speakers are front loaded onto the baffle - probably. To test the cab - go through the jack panel in rear - probably.
Nov 22, 2017 | Peavey Music
# 1991 peavey classic chours 2x12 scorpion speakers one speaker makes a buzz noise only on a high e note only sometimes -if i want to replace the speaker do the front grill come off to remove spekaer
Normally on older Peavey amps the grill is on a frame attached to the face held on with velcro. I suspect you have something vibrating against the speaker if it's only one frequency. Once the grill is off it may be apparent.
Also on old Scorpions and Black Widows Peavy has a piece of foam in the hole in the magnet to keep junk from getting in the speaker. Over time it crumbles and opens that hole, but even worse can get it the gap and freeze the voice coil. I always suggest cleaning it out while the speaker is out of the cab.
Nov 12, 2016 | Peavey Music
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Dec 10, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Wiring diagram for peavey sp4g
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Feb 07, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
HOW TO CONNECT THE SPEAKERS
What type of speakers r they and what do u want them hooked up to?
Dec 16, 2011 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
How do I go about disassembling my peavey 6150+112 combo guitar amp to the point where I can replace the 12" driiver for a better one.
Most Peavey speakers you will have to just remove the grille in front of the speaker. These usually are held by Velcro like fasteners that you must carefully pry the grille out. That will give you access too the screws holding the speaker rim. Be aware that there are different sizes of speaker rims and mountings for the "same" listed size speaker. Also use the same impedance speaker as the original one or you MAY find you have less power OR blow your amp out.
Jul 30, 2011 | Peavey 6505+ 112 Combo Amp Combo
I have a blown Diaphram, and want to replace with new one. How do i gain access/open the enclosure. Its the cabinet with that hammertex material.
Almost all of these speakers now are accessed the same way... through the front.
You will USUALLY find a few small screws through the metal grille work. There MAY be some at the midway point of top to bottom as well. The grilles OFTEN "tuck" into grooves at the sides. With the screws out you usually have to pry out the grilles. Often there are rubber channels over the edges... note how they go on for reassembly. Pry out the grille at the center of the top OR use a hook with a handle to distort the grille outward so the edges come out of the grooves.
You will have some frustration getting the grille in and out... I do on mine...
Feb 13, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
I have a new peavey sp4 speakers and blown up my HF, I NEED HELP OF HOW TO OPEN THE FRONT NET OF THE CABINETS SO THAT I CAN UNSCREW THE HORN?
Jan 09, 2011 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Need to remove speaker how do we dismantel the speaker cabinet for the sp5
you do not need to dismantel . first remove the front grill which is held in place by screws which you are able to see. you need to get a special screwdriver for this, looks like a star screwdriver but i think it has about 6 slots. then only will you will be able to remove the speakers. if you are only removing the diaphragm , all you got to do is remove both handles and unscrew the the driver . then remove the diaphragm from the driver and replace with the new one
Dec 24, 2010 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Music Logo
81 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
