Question about Garden
How do I replace the blade belt on my stiga ride on MODEL SD98
I have the belt and its fitted in the right way but i cannot get enough slack to put it over all the pulley's.
lemmingleejn
  • 173 Answers
SOURCE: Replacing the belt on a Murray Riding Lawnmower.
The simplest way, is to take hold the belt, with the tension from the engine pully/clutch mechanism, then to follow the shape around the rest of the cutter mechanism. (You don't have to worry which direction the belt travels,)
Bearing in mind, the tensioner direction.
Then, you will see the correct route, very quickly:)
Hope you can manage, with that.
Posted on Jul 23, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
JimKellyfan
  • 15 Answers
SOURCE: Belt cam off my Bolens ridding lawn mower 2005
I have the same issue on my neighbors lawnmower.
Good thing is though, the manuals are available online.
Bad thing is the actual service manual, you can buy from their 800 number.
What I did, was merely copied pages from the parts manual, as well as the owners manual. Looks like my Craftsman, whereas you need to take the top off ( seat and back cover ) to get to the two drive belts.
It is not as bad as it looks, especially with the photos helping.
Word of advice, any pulley pley, replace all parts relevant, especially attaching nuts. If not, utilize a threadloocker. Ensure to torque to spec as well with torque wrench, the blades when doing those. Typically, people need to change these at the same time, as maintaining is usually not handled partially, it is usually not at all.
Posted on May 12, 2010
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
Cutting blades not engaging when lever is pushed to engage.
First make sure that you have the right belt. If you have the right belt for your model then you have laced it wrong on the wheels. You will have to get a diagram of your belt path and redo it.
Apr 05, 2016 | Garden
Finding replacement belt from UK for McCulloch hornet ride on mower
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
Hope this helps someone.
Aug 01, 2012 | Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I have a john deere sabre 15.5/42 and cant figure out how to put the deck belt back on
Remember to always put the V side of belt (inside of belt) into the pulleys and put the flat side of belt (outside of belt) up against the idler pulley (the one that moves to make belt tight to engage blades) Make sure you have the right belt and follow those guidelines and the belt should go right on. If you happen to have alot of slack then you have to figure out a different routing around the idler. Make sure the blades are NOT engaged. When on properly the belt will be snug.
Let me know if this helps.
roundo4
Aug 28, 2009 | Garden
Cannot fit pwer steering belt toyota tercel 1994 with a/c
Make sure you routed it correctly. One of the most common mistakes I make is trying to put belt around a tensioner that belt just rides on. Hope that helps.
May 04, 2009 | 2001 Toyota Avalon
I need to put a blade belt back on my Craftsman yard tractor
If you disengage the Blades like you normally would, this will give you plenty of slack in the belt to put back on. There should be a pulley or lever that tensions the belt when it is engaged and that is what is causing it to be too tight to put back on. Hope this helps
Apr 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
Apr 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Engine pulley belt seems too short
Double... nay, tripple check that you bought the right belt. There are a zillion belt sizes and different brand may mean a different fit for the same numerical size. If you purchased a serpentine belt thats the same size as a regular belt, it might not fit your application... just because it is serpentine. Also, The department stores sell a specific set of brands of mower parts. Not every store will have every ajor brand part.
If you definately have the right belt, you might be able to find a mechanism for providing slack to our belt for installation, like a clutch pulley on a spring. By forcing the clutch pulley "in" you might get enough slack. Installation of snug belts is certainly an art. I find that prying the belt into the groove of the pulley while its turning makes it easier.
Oct 11, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
