Faulty lid sensor on WFT6500 - Washing Machines
How do I get the trunk sensor to shut off on the dash?
Close the trunk.... Just kidding
this might sound odd but it sound like the sensor that sees the trunk as closed is either mis adjusted or faulty.
spray a squirt of penetrating oil like wd40 into the receiver that secures the trunk lid. For example the lid should have a loop or square of metal that when the trunk lid is closed joins with the locking mechanism.
Shoot a a squirt of we 40 into the locking mechanism and see if the light goes out.
Feb 01, 2015 | Cars & Trucks
WFT6500 not spinning
have a look at the brushes on the motor, they may have worn down
May 20, 2014 | LG Washing Machines
Fisher paykel dishdrawer lid will not stay locked
Assuming this is happens with only one drawer - most likely controller is recongising some sensor problems. If the water inlet is faulty then it is waiting for water to get in. Alternatively, the sensor that tells it the drawer is closed suddenly misbehaves and confuses the controller which stops the cycle.
Feb 13, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Gw511
Your lid will not lock will this Error code.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
(Refer to Section 2.7.2).
37
Jun 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune L1 code came up. Washer does not seem to be spinning either. What could it be?
When an "L" error code appears, it is normally caused by one of two issues, a faulty lid locking switch, which is designed to hold the lid securely closed during the wash cycle, or a faulty lock solenoid sensor, if bad, this is why it will not spin. good-day !
Dec 03, 2011 | Maytag Washing Machines
Door open (Hp4255)
printer cartridge lid open try to open the lid again, if already open the possibility of faulty sensors replace the sensor
Jul 18, 2011 | HP OfficeJet 4255 All-In-One InkJet...
I have a Maytag Bravo for 1 month and it's showing an error code L id. What does this mean? I have checked everything that I can think of.
First make sure the lid is completely closed, and try running the washer. Because if an "L" appears upon the electronic display area, the lid lock might not be working properly. When an "L" error code appears, it is usually caused by one of two things, a faulty lid locking switch, which holds the lid completely closed during the wash cycle, or a faulty lock solenoid sensor, which displays a warning signal when the lid is not locked securely. If one of these is not working properly, you need to replace the part.
Feb 24, 2011 | Washing Machines
When a load goes to the rinse cycle it the drum won't turn.
For a top loader, a common source of this problem is a defective lid switch. (Check to make sure that the lid is fully closed) Faulty timers, faulty water level sensors, faulty water level selectors can sometimes produce similar results.
Jan 13, 2011 | Washing Machines
The load won't start.
Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
