Question about Dell Computers & Internet
Dell h235p-00 power supply - Dell Computers & Internet
Electrical circut of pa-1650-05D
Try Ebay they have all kind of power supply for laptop, I found a replacement for most of the one I seek for.
Jan 04, 2014 | Dell Part Number PA165005D PA165005D2...
N375P-00 POWER supply
Just buy a new power supply, they are considered disposable parts. It's probally a retefifier or diode.
Mar 17, 2012 | Dell Computers & Internet
What are the Schamatics to a Dell ac/dc adapter MODEL: DA90PS1-00
Specification of DA90PS1-00 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W MaxOutlet: 3-Prong
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Sep 18, 2011 | Dell Laptop DC Power Jack (DELLDL271600)...
Adapter does not chanrge
make sure its plugged in correctly and the wall plug is plugged tightly. I had a Dell C840 when the
charger got power it had a green diode that lit up. You could test your power supply with a volt ohm
meter. if the VOM is not showing any power coming from the power supply (assuming you have the
VOM setup to match the power output of the power supply) then the power supply is probably bad.
If it works then it could be the computers connection or battery.
May 14, 2011 | Dell l 1X917 310-2860 DA65NS0-00 DF261...
I jus left my computer optiplex gx260 on and when
Your automatic update from microsoft probably updated your machine and shut it off, by default it is set to update if their is one, every tuesday at 2:00 or 3:00 am and will either restart or shut down your machine.
if thats not it then your computer may have gone into hibernation or standby.
May 25, 2010 | Dell POWER SUPPLY Power Supply
My dell studio 1737 will not charge the battery; however it will run on either the battery or the power supply at leas until the battery dies completely. The power supply is working properly. I have tested...
If the power supply is powering the system without the battery installed, and the battery powers the system without the power supply attached, but the power supply will not charge the battery in the system...chances are very high the charging circuit on the systemboard is not functional. There are a few possibilities as to why but the only real solution would be to replace the systemboard since the charging circuit is integrated. You could run through the charging circuit to locate the exact fault but you will need schematics in order to resolve if you are comfortable with micro-soldering.
To verify, if you can, place the AC adapter and battery into another 1737 and see if you get charging on the battery.
May 22, 2010 | Dell Studio 1737 Laptop
Hi is the Power supply on a 2006 Dimension 5150
What makes you think you have a dead power supply? I would look at the connectors and see if there are 20 or 24 going into the Motherboard main connector. Then look for a 4 pin connector plugging in near the CPU. If it looks like the mounting holes line up, you have a winner. Most are interchangeable anyhow. Try to get some SATA connections on your new one.
Dec 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer suddeny refused to turn on/boot whatsoever
it sounds like the hardrive you installed overloaded the system and cause a low power operation on the computer the motherboard may be bad because of this as well as anyparts that were connected to it i have had this happen to me before and well i know it sucks but your best bet is to just buy a new computer and make sure you power supply can handle extra parts...
Apr 08, 2009 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
1,001 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
