Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
Heater won't start
After being plugged in, the heater hums as though it wants to start, but after a few seconds it stops. This happened suddenly. It was working fine the day before.
    Novelist:
  • 88 Answers
Thanks for your question,
Sounds to me like you have a faulty fan in the unit, could be stuck, or might be a bad fan motor, try unplugging it first, find something to insert where the fan is and try spinning the blade, if its stuck or has alot of resistance, then you have a bad motor, if its free spinning, then try plugging it back in and see if it works, sometimes just by manually moving the motor shaft it frees it to work, if it still doesnt work, then you might look at replacing the fan motor, or replacing the unit, hope this helps ya,
mr.grzz
Posted on Jan 25, 2009
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
The temperature, speed, and gas guages arent working on my 2000 Dodge Caravan 4 cylinder. The milage only lights up for a few seconds then goes out. My Dash lights work though. Also when this happens my...
G'day mate it would seem that the fuses though on inspection are fine they may be not so good if removed for inspection also remember that if the fuses are dirty that moisture will carry a voltage to earth on a dirty damp circut. also there should be another fuse box near the battery with higher amperage fuses hope this helps
Apr 03, 2010 | 2000 Dodge Caravan
1999 Mazda 626 antenna won't go down, hums.
Spray the antenna with a spray lubricant (WD40) or similar. and let it sit for an hour.
Then start the car and see what happens.
The antenna is probably full of filth or corrosion..
If that doesn't work take the side cover off the trunk on the side where the antenna is and you will find a plug in electrical connector near the motor that winds the antenna up and down, pull that plug out and the antenna will stop trying to wind itself down..
May 09, 2009 | 1999 Mazda 626
Frigidaire built stacked washer and dryer
There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Heating & Cooling Logo
452 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
