Question about Canon PowerShot G2 Digital Camera
Powershot g2 power schematic
I broke on of the 9vdc pins off and i am looking for a schematic for the power as i am unsure of the polarity of the pins, can some one help so i can make another type of mains power supply connection. please help
    Genius:
  • 2,985 Answers
I doubt you will find such a thing- altough- Canon web site tech support may have a clue. but you should not need it if you have the skills to make such an item- just make it and stick it where the other came out.
Posted on Jul 15, 2007
Model 2011 jay flight g2 when hooked to AC power has 120 volts on external TV connector. Can I get an electrical schematic for the 29RLS floor plan?
What you are saying is when you connect that motor home to a shoreline power connector, the outlets are reverse polarity. You can confirm that with something like this: http://www.acmehowto.com/electrical/outlettest.php
You can get this tester at any hardware or lumber place. What caused this? Somehow the polarity got reversed and it is most likely at the connection on the outside socket. It can also be the shoreline drop cord or the breaker box. In an electrical outlet, the small slot is HOT and it should be connected to a BLACK wire. In an appliance like a television the neutral wire (white) is connected to the ground or the chassis of the device, when the polarity is wrong the chassis becomes hot and you get the problem you describe.
Oct 07, 2016 | Computers & Internet
Hi, i need to know the exact power plug so i dont have to run the pedal on battery power.i know i need a 9v power supply but i dont know the size of the jack that goes into pedal..many thanxs..
Unfortunately, battery jacks and plugs similar to the type you're describing do not have any real standardization - unlike the outlets and plugs in homes and businesses have.
You best bet is to either bring the plug / jack to a shop to match it or contact the instrument's manufacturer to obtain the connector specs for physical dimensions
Be sure to obtain the power requirements in either watts or amps so that you can obtain a power source capable of delivering what you need without overheating during longer periods of use. Adding 25% to 50% more amps or watts to the minimum required should provide years of trouble free service. Example: 9VDC at 50 watts should be supplied by a 9VDC 62 watts or even 75 watts; or in the case of a rating of 9VDC at 6 amps should be supplied by a 9VDC at 7.5 amps or even 9 amps. With DC powered devices, make sure you observe proper polarity! Good luck!
Mar 16, 2016 | Music
Blueparott B250XT Charger Specs
9vdc positive tip. Road King RPDC-812 available at most truck stops work great it's a universal dc adapter and the orange end fits the 250xt. Price $15 at Love's.
May 01, 2012 | VXI Corporation Blueparrott B250-XT...
Eject system doesnt work. wont seat a flash card
It's easy to insert the card incorrectly...double check it.
Dec 30, 2009 | Canon PowerShot G2 Digital Camera
External power problem
It's actually the opposite. 1/8" jacks are almost always positive tip. I think you are best off using a 9VDC supply. If the voltage is not staying constant at 9 volts it could certainly do damage. If the supply you used was a negative tip positive sleeve you may have burned out a component or two...and more voltage than recommended could have done some other bad things. If it does not work with a 9VDC supply with the correct polarity you can fix it yourself if you have electronic experience. You could also send it to me and I'll fix it at a reasonable rate.
Aug 26, 2009 | Ibanez Ts808 Vintage Tube Screamer Reissue
How do I obtain a "Date Battery" for a Canon PowerShot G2?
Please see page 130 of the following:
http://gdlp01.c-wss.com/gds/0900001283/PSG2CUG-EN.pdf
The CR2016 is a very generic button battery. Take a look at your local pharmacy such as Walgreens or Rite Aid. Have even bought them at Walmart's watch and jewelry department (Though Walmart was shockingly more expensive than the pharmacies). Shouldn't cost more than 3 or 4 dollars.
Jun 04, 2009 | Canon PowerShot G2 Digital Camera
Unable to load cf card in slot
The pinholder inside the camera has a bend pin or broken pins. You must let it repair. Ask Canon for an proforma invoice. Rotronica in the Netherlands can repair it for you, the cost is approx. 75,00 Euro.
regards,
Rob
Apr 30, 2009 | Canon PowerShot G2 Digital Camera
Canon g2 digital camera will not keep charge
I have the same problem with my G2. Many people have this issue and all Canan could tell me is they would glady look at my camera and fix it for a fee. The fee unknown until they have my camera.
Apr 08, 2009 | Canon PowerShot G2 Digital Camera
No date/time stamp
peut etre en changeant la pile plate cachée sur le coté de l'emplacement de la batterie
Apr 11, 2008 | Canon PowerShot G2 Digital Camera
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Jun 10, 2007 | MidiLand MLi 691H Computer Speakers
Canon PowerShot G2 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
