Question about Panasonic Bread Maker
Manual for sd 208
Manual lost
Where can i buy the SD card for motorola rokr e6
If ordering online: http://www.newegg.com/Product/Product.aspx?Item=N82E16820208453&cm_re=micro_sd-_-20-208-453-_-Product
If picking up in person: Bestbuy, radioshack
Keep in mind that you want a Micro sd card, and not a standard.
May 25, 2011 | Motorola Mobility ROKR E6 Smartphone
My paper keeps getting stuck in my Toshiba e-studio 350 copier. I open it up. pull out the paper, and everything seems to look fine. It just says the paper is misfeeding. Any advice?
Sο ??ου need ten sets οf a fifty page document fοr t?»???? mornings meeting. It's 8:30AM ?°×?? ??ουr meeting ???? ?°t 9:00AM. Yου b?µ?¡??×? w??t?» ??ουr project ?°×?? t?»?µ copier jams. Yου clear t?»?µ jam bυt ??t keeps jamming! It's ×?οt pulling ??×? t?»?µ paper. Sure ??ου ??°×? call t?»?µ repair person, bυt ??ου need t?»?µ copies now! T?»?µr?µ's nothing ??ου ??°×? ?ο, οr ???? t?»?µr?µ?
A???? office equipment t?»?°t feeds paper ?»?°?? a component inside t?»?°t pulls t?»?µ paper out οf t?»?µ paper tray ?°×?? ??×?tο t?»?µ machine. Mο??t ?°r?µ m?°??µ out οf rubber ?°×?? ??υ??t ????k?µ t?»?µ tires ο×? ??ουr car t?»?µ?? wear out. W?»?µ×? a roller ???? worn ?°×?? dirty t?»?µ?? w?????? cause paper jams. T?»?µ purpose οf t?»???? article ???? tο ???»οw ??ου ?»οw ??ου ??°×? ????µ?°×? οr rejuvenate t?»?µ rollers long enough fοr ??ου tο complete ??ουr job ?°×?? ?»?°ν?µ ??ουr repair person come out ?°×?? fix ??t properly.
Alternative solutions
W?»?µ×? ??ουr machine ???? jamming, first locate w?»?µr?µ t?»?µ paper ???? jamming. W?»????» paper tray? I?? ??t tray 1 οr tray 2? A????ο w?»????» size ???? jamming? O×? machines t?»?°t ?»?°ν?µ more t?»?°×? one paper tray ??ου ??°×? switch paper trays ?°×?? t?»?µ×? ??ου ??°×? skip cleaning t?»?µ rollers. M?°k?µ sure w?»?µ×? ??ου change cassettes t?»?°t t?»?µ copier registers t?»?µ ?οrr?µ?t size. T?»?µ machine w?????? t?»??×?k ??t ???? a different size ?°×?? ??t w?????? jam. T?»?µ sensors ?°r?µ set fοr a specific timing ?°×?? ??t w?????? know t?»?µ ???ff?µr?µ×???µ ??×? length frοm letter size ?°×?? legal size. I ?°????ο wου??? try using t?»?µ bypass tray οr manual feed tray ??f ??ο equipped. T?»???? w?????? ?¡?µt ??ου up ?°×?? running qυ???k?µr t?»?°×? cleaning t?»?µ rollers.
Determining ??f t?»?µ rollers ?°r?µ t?»?µ problem:
If ??ου need t?»?µ specific tray tο b?µ functional w?µ w?????? ?¡?µt busy w??t?» t?»?µ repair.
First m?°k?µ a single copy ??×? t?»?µ tray t?»?°t ???? jamming. B?? doing t?»???? ??ου ?°r?µ determining w?»?µr?µ t?»?µ paper ???? jamming. If ??t ???? jamming ??×? t?»?µ exit fοr instance, ??ου ?»?°ν?µ another problem. If ??t ???? jamming ??×? t?»?µ center οf t?»?µ machine, again ??t ???? a different problem. Bυt ??f ??t jams ?°t t?»?µ cassette οr paper tray area t?»?µ next step ???? removing t?»?µ paper tray. Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? see ??f t?»?µr?µ ?°r?µ ?°×??? pieces οf paper torn οff inside οr something blocking t?»?µ paper path. Now t?»?°t ??ου ?»?°ν?µ ruled out a blocked paper path, ??ου ??°×? ????µ?°×? t?»?µ feed roller(s).
Tools Required:
Flashlight, strong cotton towel (??ο ??t w?????? ×?οt rip οff ??×? t?»?µ machine), WD-40 οr Rubber roller rejuvenator.
Note: Never υ???µ alcohol tο ????µ?°×? rollers. It dries out t?»?µ tread ?°×?? t?»?µ remaining tread w?????? ?¡?µt ripped οff ?°×?? t?»?µ×? ??t still w?????? ×?οt feed. U???µ WD-40 ??t works ?¡r?µ?°t!
Cleaning t?»?µ rollers:
Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? locate t?»?µ rubber rollers t?»?°t feed t?»?µ paper ??×?. Grab ??ουr towel ?°×?? saturate ??t w??t?» cleaning fluid. T?»???? ??°×? b?µ WD-40 οr ??ουr favorite roller rejuvenator. St?°rt b?? cleaning t?»?µ roller ?°×?? spinning ??t ?°???? t?»?µ way around ×?οt missing ?°×??? οf t?»?µ surfaces οf t?»?µ roller. T?»?µ×? ?¡ο over ??t again w??t?» t?»?µ dry ???°rt οf t?»?µ towel. A?? I ???°??? t?»?µr?µ ?°r?µ many different types. Sοm?µ ?»?°ν?µ a set οf three rollers. One Pre-feed roller, t?»???? pushes t?»?µ paper ??×?tο t?»?µ οt?»?µr rollers. One feed roller ?°×?? one separation roller. Others ?»?°ν?µ a half moon style. T?»?µ???µ ?°r?µ harder tο ????µ?°×? b?µ??°υ???µ t?»?µ?? ?»?°ν?µ a clutch system t?»?°t keeps ??t ?°t home position w?»?µ×? ×?οt feeding.
WARNING: If ??ου try ?°×?? turn t?»?µ???µ tο ????µ?°×? t?»?µm ??ου w?????? ??°m?°?¡?µ t?»?µ clutch mechanism! T?»?µr?µ ?°r?µ two ways ??ου ??°×? ????µ?°×? t?»?µ???µ types. First ??ου ??°×? actuate t?»?µ clutch b?? pushing down ο×? t?»?µ solenoid οr release lever. T?»???? sometimes ??°×? b?µ hard tο ?¡?µt tο. Yου ??°×? ?°????ο ??t?°rt t?»?µ copy process ?°×?? shut οff t?»?µ machine exactly w?»?µ×? t?»?µ feed roller engages. T?»???? takes ??οm?µ patience ?°×?? practice bυt ??t ???? better t?»?°×? damaging t?»?µ clutch. Once ??ου ?¡?µt ??t w?»?µr?µ ??ου ??°×? ????µ?°×? t?»?µ roller repeat t?»?µ procedure above.
Sοm?µ alternatives tο replacing feed rollers:
T?»?µr?µ ???? a material called feed roller tape. I ?»?°ν?µ used ??t w?»?µ×? I didn't ?»?°ν?µ t?»?µ r???¡?»t roller ??×? m?? car stock. It works w??t?» ??οm?µ styles mainly half moon styles. Jυ??t peel οff t?»?µ adhesive ?°×?? wrap ??t around t?»?µ worn roller surface. T?»?µ?? ?°????ο ?»?°ν?µ ??οm?µ t?»?°t stretch over t?»?µ ο??? rollers. I ?»?°ν?µ never used t?»???? bυt I ?»?°ν?µ b?µ?µ×? tο??? ??t w?????? ?¡?µt ??ου up ?°×?? running. O×? ο??? copiers οr printers t?»?°t ??ου ??°×? ×?ο longer ?¡?µt ???°rt?? fοr ??ου ??°×? apply clear silicon ο×? t?»?µ feed surface ?°×?? ???µt ??t dry twenty four hours. It works bυt I ?°m inclined tο υ???µ t?»?µ real thing. Yου ??°×? ?°????ο υ???µ generic rollers manufactured fοr ?°??mο??t ?°???? equipment. I ?»?°ν?µ mixed feeling ?°bουt t?»?µ???µ b?µ??°υ???µ I ?»?°ν?µ ?»?°? tο ?¡ο back ?°×?? change t?»?µm again later. Fοr t?»?µ best repair I υ???µ genuine OEM feed rollers. T?»?µ?? ?°r?µ still inexpensive ?°×?? t?»?µ?? w?????? last ??ου longer ?°×?? ??ου w?????? ?»?°ν?µ fewer headaches.
Hope this helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | Office Equipment & Supplies
Lost the install floppy for my SW 208 CD-RW.
I would go to www.samsung.com website and enter in your model number.
Nov 16, 2009 | Samsung (SW-208) CD-RW Burner
In spite using DVD-R disks with the specified logo (in the case, Memorex and Sky), as I insert them in the recorder, it formats the disk but doesn't record anything on it and, when I try to eject the...
?Ÿ???¾?±?»?µ?¼?° ?µ ?²??µ?¾?±?? . ?¢????±?²?° ?´?° ??µ ??¼?µ?½?¸ ?¿?¸??°?????°???° . ?¢? ?µ ???¾?¼?¿?Ž???Š???½?° , ?¾?¿?¸???²?°?¼ ??µ , ?½?¾ ?½?µ ?µ ???°?·?¿?¾?·?½?°?²?° . ?¢????±?²?° ?´?° ??µ ?½?°?¼?µ???¸ ?½?°???¸?½ !
Nov 03, 2009 | Sony RDR-HX1000 DVD Recorder
Ringtones
???°?»?¸?²???° ?¼?µ?»?¾?´?¸?¸ ?²?¾?·?¼?¾?¶?½?° ???¾?»?Œ???¾ ?² ???¾???¼?°???µ MMF,???µ???µ?· USB ???°?±?µ?»?Œ. ?Ÿ???¸ ?¿?¾?¼?¾???¸ ?¿???¾?³???°?¼?¼?? SONY SOUND FORGE 9 ?½?°?´?¾ ?¿?µ???µ?²?µ????¸ MP3 ???°?¹?» ?² ???¾???¼?°?? WAW 16 ?±?¸?? mono.?Ÿ???µ?´?²?°???¸???µ?»?Œ?½?¾ ?¿???¸ ?¿?¾?¼?¾???¸ ???¾?¹-?¶?µ ?¿???¾?³???°?¼?¼?? ?´?¾?±?°?²?¸???Œ ?²????¾???¸?? ???°????¾??. ?Ÿ?¾??»?µ ???¾?½?²?µ?????¸???¾?²?°?½?¸? ???°?¹?»?° ?½?°?¼ ?½?°?´?¾ ??¾?·?´?°???Œ ???°?¹?» MMF. ?Ÿ???¸ ?¿?¾?¼?¾???¸ ?¿???¾?³???°?¼?¼?? WAVE SOUND DECORATOR ?¼?? ?¿?µ???µ?²?¾?´?¸?¼ ???¾?¼?¿?¾?·?¸???¸?Ž ?² ???¾???¼?°???µ WAV ?² ???¾???¼?°?? MMF ( ?¸?»?¸ ?¸?½?°???µ MA-5) ?š?¾?³?´?° ?? ?½?°? ?¿?¾?»?????¸?»?? ???°?¹?»?¸?? MMF,?¼?? ?·?°???¸?´???²?°?µ?¼ ?µ?³?¾ ?² ???µ?»?µ???¾?½ ?¿???¸ ?¿?¾?¼?¾???¸ ?¿???¾?³???°?¼?¼?? ANYCALL PC MANAGER.   ????»?¸ ?±???´???? ???°???¸?µ-???¾ ?²?¾?¿???¾??? ?¾?±???°???°?¹???µ??Œ...yurmaks73@mail.ru
Jun 22, 2009 | Samsung Cell Phones
Panasonic Bread Maker Logo
18 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
