Question about Electrical Supplies
How to set merlin gerin timer multi9 IH 24 h 2C ARM timer
3 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: i am looking for a merlin gerin circuit breaker
Her ya go:
http://www.drillspot.com/products/160507/Merlin_Gerin_MG24434_Miniature_Multi9_Circuit_Breaker
Posted on Feb 21, 2009
  • 5245 Answers
SOURCE: Need the programme on how to set timer - Merlin Cat No. EDT Batch 29
Add a comment and describe timer in detail
http://waterheatertimer.org/How-to-set-timers.html
Posted on Apr 17, 2013
How to set merlin gerin timer IHP 1C, 365 d
try this
http://www2.schneider-electric.co.jp/appl/Elibrary/SETechnical_DB_INT.nsf/8a6913e20cdd8337492572b4000e156d/ebb677d0105fa26349256e0000169227/$FILE/4291364B.pdf
Mar 10, 2013 | Audio Players & Recorders
How to convert bis 10 desk set to a bis 10 wall set
Western Electric produced 2 different stands for "Classic Merlin" telephone sets. You will need to locate the stand designed for wall mounting. Such stands appear on eBay from time to time. Keep in mind that Classic Merlin telephone sets were discontinued many years ago so locating the correct base might be a bit of a challange.
Apr 11, 2011 | AT&T Merlin BIS 10 Phone
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Can I make the Merlin BIS 10 Phone able to use a
Yes, Plantronics sells a myriadof different headsets that should work well with Merlin sets.
Sep 10, 2009 | AT&T Merlin BIS 10 Phone
Motor starter is tripping the breaker
this problem has to be solved by process of elimination first make sure the voltage used is the correct voltage the next step is to disconnect the motor wires from the starter and turn on the power if the starter engages u have a bad motor if breaker trips starter or power cable is shorted a direct on line 220 volts rated at 20 amps motor starter will work just fine or contactor and overload relay at 20 amps 220 volts ( GE, allan bradly,merlin gerin,legrand are some brand manufactures
Apr 05, 2009 | Delta 10" 3 Hp, 230V, Single Phase, Right...
I am looking for a merlin gerin circuit breaker but i cant find out where i can buy it from.
Her ya go:
Feb 19, 2009 | Merlin Gerin MG24434 Miniature Multi9...
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
Electrical Supplies Logo
73 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
