Question about Philips TV / PC Video / FM Graphic Card
Asus video security "set frame rate" error
I installed the v562 asus tv tuner cd and loaded the video security and I set all possible parameters and it appears to be working. Until it starts to capture and record then this error occurs. You have to acknowledge in order for it to resume. It says to "set frame - rate " error, but i do not have any way of doing this. Is there something i need to down load? I did install directx:9 and still have this problem.
  • performancer Nov 23, 2009
    Did you fix this problem mate? I am having the same issue. cheers
  • 68 Answers
Hi...
firstly i would recommend you to go through the document that came with the video security software...
there has to be a way to set the frame rate..
the reason your getting this error is because your card cannot process the frame rate which is currently set...!!
Posted on Jan 27, 2009
Install cd
download link for the drivers for this Tv2_bing.gif Tuner PCI Card is below Please Rate if this is helpful as this lets me know if I'm actually helping people... Thanks
http://videodrivers.es/ws-tvp7130fm-tv-tuner-pci-card-philips-7130-wfm-driver/download-1980.html
Model:PC TV Philips2_bing.gif Capture 7134/7130
Support OS:Win95, Win98, Win98SE, WinME, WinNT4, Win2000, WinXP, Win2003, WinVista, WinVista
Jun 08, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
My external frequency is set wrong and should like to know what it is.Its an asus p4s8x-x hope you can help thank you
The Asus P4S8X-X has C.P.R.
CPU Parameter Recall
(Central Processing Unit, or Processor)
Restart the computer, and BIOS will set the CPU parameters back to the factory default settings.
Internal frequency rate times the multiplier = external frequency rate.
The Asus P4S8X-X uses Intel processors (Socket 478) that have either a 400Megahertz Front Side Bus, or a 533MHz FSB.
Since you did not state what socket 478 Intel processor you have installed, I cannot tell you what the external frequency rate is supposed to be.
(At maximum operating capacity)
Have you installed a different Processor?
Were you trying to overclock?
What led up to this?
Jun 07, 2010 | Computers & Internet
It gives me error when i setup tuner
Upon installing your Philips SAA7130 TV tuner/Fm radio/ Video PCI Capture Card. You can switch your PC on, and get connected to the internet without opening any window. Left click the Control Panel, and the Add hardware wizard. Then follow the instruction. You will be prompted to load your CD installer software driver, if the PC cannot find any driver soft-
ware in the O.S., In case you don't have a CD, your
PC will look it by itself at the internet since you are already connected, just follow and wait to get it installed. Hope this helps.
Dec 12, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have just bought a car with an overhead tv i dont know how to get power to it
    Headrest TV
  1. Step 1 Disconnect the headrest from the car seat and remove its upholstery. Trace the outline of the TV's mounting frame onto the foam cushioning with a permanent marker.
  2. Step 2 Cut a hole into the foam using a razor knife for the frame to fit into. Using the frame as a guide, whittle into the hole until it is deep enough for the frame to fit into. Glue the frame into the hole with contact cement and poke another hole into the foam with a screwdriver where the frame's cable hole is.
  3. Step 3 Place the headrest's upholstery cover back on and cut the fabric away where it is over the frame.
  4. Step 4 Place the TV into the frame once the contact cement is dry and hard and run its cable through the other hole. Connect the TV to its tuner console with audio/video cables and store the tuner under the seat.
  5. Step 5 Connect the TV's power adapter cable and route it so it can plug into a cigarette lighter adapter. If it doesn't use one of these, it will have a three-way cable where one connects to the car starter, another to a constant 12-volt source and the last one to a good ground. Disconnect the negative battery cable before connecting any wires
  6. Overhead TV
  7. Step 1 Make sure there is a metal sheet installed in the ceiling below the headboard. This is needed to mount the overhead player onto.
  8. Step 2 Pull away the upholstery on the ceiling. This might require a solvent that will remove the upholstery's adhesive. Insert a plywood or metal sheet between the headboard and upholstery and glue it to the upholstery.
  9. Step 3 Mount the TV set to the ceiling, making sure the screws for the TV's mount are securely screwed into the sheet within the ceiling.
  10. Step 4 Route the wires to the engine compartment if the TV doesn't use an adapter plug for the cigarette lighter. With the negative battery cable unplugged, connect the TV's red wire to the starter's electrical connector, the yellow to the battery or other 12-volt source and the black to a metal ground like on the chassis.
  11. Dash TV
  12. Step 1 Unplug both battery cables from the car's battery, starting with the negative terminal.
  13. Step 2 Remove the stereo from the car. Pry away and remove any trim panels on the dash, then unscrew the mounting screws on the stereo and disconnect the electrical connectors. Some stereo units have an anti-theft mounting system requiring special tools that fit into holes on the stereo front to release its mounting clips.
  14. Step 3 Place the TV within an installation kit designed for your model carmag-glass_10x10.gif. Connect the antenna's cable to the TV and mount the antenna on the outside of the car; the trunk or the roof near the door frame are two possible locations. Route the cable along the weatherstripping or secure it to the side with cable ties.
  15. Step 4 Connect the TV to its tuner box with RCA video (composite) cables and store the tuner somewhere secure, like the glove box. Wire the TV to the radio antenna and stereo connectors with a wiring harness designed for your car, which can be purchased at a car audio supply store.
  16. Step 5 Mount the TV into the stereo's old spot within the dash, fasten all the mounting screws and replace the trim panels. Reconnect the battery cables once the set is mounted, starting with the positive terminal.
i hope this will help.you can send a message if you not satisfied
Sep 10, 2009 | Necvox Car Audio & Video
Asus tv tuner v562
you can use this link for download any kind to driver
http://www.driverguide.com
May 29, 2009 | ASUS TV Tuner (610839008506) TV Input
Installation of tv tuner of philipse 7130
Here is a driver for the card, install it and restart, should be good to go. Comment back if you have any further questions. Good Luck
http://cr.am/framed.php?url=http%3A%2F%2Fmembers.home.nl%2Ffly2000%2Ffiles%2Fdrivers%2Fsaa713x_2310.zip&ref=driverguide
Apr 06, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Driver problems with OEM 7130AA WDM Video Capture device (Phillips chipset)
Hi.
Use this to update your drivers
http://rapidshare.com/files/149632922/Driver_Scanner.rar
Hope this helps.
Regards
Faraz
Oct 14, 2008 | Philips TV Tuner Video Capture PCI Card -...
Video controller problem PLEASE HELP !!!
Hi bullterrier0,
The Asus P4S8X-MX uses an onboard video controller, (SiS Real 256E graphics card).
There is an order of sequences that must be followed when adding another video card on to the motherboard. If these are not followed your new card will not function correctly. Shut down the system. Unplug the power cord from the PC. Open your case.
Please remove any graphics cards you may have added into the system, (For now). Once removed leave your case open & plug the power cord back into the PC. Press the start button. Start pressing the Delete key every two seconds as the PC starts up.
The bios main menu will load. Instruction on how to move about within the bios is listed at the bottom of the menu. You will need the P4S8X-MX manual. (If you no longer have the manual you can download it from Asus by clicking on this link:
http://support.asus.com.tw/download/download.aspx?modelname=P4S8X-MX&SLanguage=en-us
Click the plus sign next to; Manual. Find the English manual.
Create a folder on you're desktop & name it Manual. Download the manual. Save the manual into the folder. The manual will need Adobe pdf reader to be viewed. If you do not have Adobe you can download it for free from this link:
http://www.adobe.com/products/reader/
Once into the bios go to the title Advanced, page 2-17 in your manual or page 59 in Adobe pdf viewer. Open Chipset sub-menu.
Than find, Primary Graphics Adapter page 2-21 in manual, pg 63 in Adobe.
If the TV turner card is an AGP set this to [AGP] & set AGP Fast Write Control to [Enabled].
If you are using a PCI TV tuner card set this to [PCI]. Save the bios & exit. The PC will auto restart. Press & hold the power on button until the PC shuts off. Unplug the power cord from the PC. Re-insert you're AGP TV video card. Double check all internal connectors for good connecting before closing the case. Plug in the PC's power cord & start the system. Once windows has finished loading install the TV video cards driver software.
If you installed software drivers for the P4S8X-MX other than driver software provided by Asus please uninstall that software through Add/Remove programs. (If at all possible).
Since you want to use a TV video card you can not use the onboard graphics card at the same time. This is why windows was restarting. Windows did not know which card to load. Once the onboard card has been disabled by telling the bios to load the AGP, (Assuming you're TV card is an AGP card) windows should run fine. There is always the possibility I interpreted your trouble incorrectly. If this is the case, please let me know & I'll adjust my answer to fit the issue.
Good luck bullterrier0!
Mike
Aug 12, 2008 | ASUS P4S8X-MX Motherboard
Philips TV / PC Video / FM Graphic Card Logo
358 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
