Question about Microsoft Xbox 360 Console
Av cable when i plug my av cable into the back of the xbox it goes to e74 but when i take it out it works fine
  • 40 Answers
E74 indicates hardware failure of some sort. It could be that when you pull the av cable you are solving the current issue (maybe its the av slot thats broken), but either way you should contact microsoft as its going have to be sent in for repair.
Posted on Jan 25, 2009
Xbox360 e74
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/kb/e74-error-appears-when-you-use-your-xbox-360-console.aspx?kbid=941377
Oct 17, 2010 | Microsoft Xbox 360 Console
Tip
How to Repair the Xbox 360 E74 Error
Oh no, it happened, you are the victim of an error on the <b>Xbox 360 E74</b> feared. Well do not worry my friend, in this article I will show you exactly how to <b>fix E74</b> error free shipping on your system in two months.<br /> <br /> The first way to correct this error is very simple, it might just be the AV cable. The first thing you can try is to unplug the AV cable and blow off the dust that could be built up contacts. Then try hooking it back up and turn it on.<br /> <br /> If you still have errors trying to get a new AV cable, or you can borrow one from a friend so you do not buy a new cable, if not the solution either. Once you have the new AV cable, plug it in, turn on your <b>Xbox 360</b>, and if the error is still ongoing, so you must go to the following method to determine the<b> error E74</b>.<br /> <br /> If the AV cable is not working, you have to go to a bit of a more complex method to correct the error. You can still fix, but the methods can be explained in an article.<br /> <br /> You can find the <b>Xbox 360 repair</b> guide on the internet which are very detailed instructions on how to correct the error E74 and other errors, such as freezing, no video problem and the Red Ring of Death. These instructions are usually very detailed step-by-step. Better manuals including pictures and video of the process, so you can be sure you understand every step of the repair.<br />
on Mar 08, 2011 | Video Game Consoles & Games
E74 error message xbox 360
now this my friend is why you dont use an xbox.
My answer? get a ps3
Oct 14, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error code
This problem occurs when the Xbox 360 console experiences a general hardware failure. Contact Xbox live 1-800-4my-xbox
Sep 19, 2009 | Microsoft Xbox 360 Console
Xbox360 was working fine till i turned it on and E74 message came up...is there anyway i can repair
here are fixes of the E74 error.
http://video.google.com/videosearch?hl=tl&source=hp&q=xbox+E74&um=1&ie=UTF-8&ei=ZmqoSpehNYecsgOxmeSFBQ&sa=X&oi=video_result_group&ct=title&resnum=4
Sep 10, 2009 | Video Game Consoles & Games
E74 code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Jun 18, 2009 | Microsoft Xbox 360 Console
Xbox 360 E74 - Need To Get Fixed
http://forums.xbox-scene.com/index.php?showtopic=484726
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement
Dec 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74 system error
E74 is NOT caused by a bad AV cable, it is NOT caused by the ANA/HANA scaler chip. It is the solder points on the GPU that have cracked. You must use a heat gun and do the XCLAMP to fix it. Shops normally charge $75-100 to fix that.
May 20, 2008 | Microsoft Xbox 360 Console
E74 error
E74 for XBOX 360 is a hardware failure.  Unplug all controllers, hard drives, memory card(s).  Unplug and reseat the power cable and the A/V  cable.  Check the power supply to see that color led lights up when you turn the console on.  If it is red or orange it is an issue with the power supply (either overheating or too much/too little power.  If you are plugging the power supply into a cheap surge protector plug it directly into the wall.  If none of these suggestions work then you need to contact Microsoft.
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
