Question about Dryers
Dryer heating problems
My dryer when first started for the day will fire up and heat and dry. but it seems that after the first or second firing cycle it wont heat anymore. the lighting element still glows put it wont fire up if I turn it off and restart it. But if iI let it sit for maybe1/2 hour it will start again.
  • 5,911 Answers
If this is a gas dryer, this is commonly caused by bad gas valve solenoids. Please post back with your make and model so I can verify your configuration and assist you further.
Posted on Jan 27, 2009
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
Dryer wgd5300, takes a long time to dry. seems
The burner is supposed to05245ec.jpg cycle on and off all through the drying cycle. Over time the operator coils 279834 get weak and quit. They are really easy to replace. This short video show a normal Burst of heat from a dry and the normal length of time it fires off
May 19, 2010 | Whirlpool WGD5300S Dryer
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
My heating element stays on for about 15 sec at a time-is this normal?
Is is normal for the heating element to cycle on and off. The element is usually protected by an operating (or hi-limit) thermostat that helps regulate the internal operating temperature. The element is not supposed to stay on continuously or you could end up with a scorched clothing, or a fire hazard. As your clothes get dryer, the heating element should cycle less. As long as you are not having any problems with dryer performance, you shouldn't have anything to worry about.
However, if your dryer is heating, but you are experiencing longer dry times or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
Mar 12, 2010 | Dryers
TAKES 2 TO 3 CYCLES TO DRY. gETS BARELY WARM
If your dryer is still heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
Mar 08, 2010 | Roper REX4634KQ Electric Dryer
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
It takes 2 or 3 cycles to dry a load
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
The number one cause of dryer heat related problems is caused by poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know. I hope this helps you.
Dec 23, 2009 | LG DLE2516 Electric Dryer
Dryer flame comes on at beginning of cycle, but goes out before the cycle is completed
Based on your issue description, Gas and electric dryers have heat sources that are controlled by a cycling thermostat. This thermostat will cycle the heat on and off numerous times throughout the drying cycle. It should never keep the heat on constantly as this would cause clothes shrinkage and a chance fot a lint fire. If the dryer is drying clothes normally then you have no problem.
Aug 03, 2009 | Dryers
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
Jun 21, 2017 | Kenmore 659 Electric Dryer
Dryers Logo
83 people viewed this question
Top Dryers Experts
