Question about Fossil AM Watches
Fossil AM3571 wrist watch
Instruction manual
SOURCE: User Manual - Fossil CH2332 Wrist Watch
go to fossil.com click on customer support that is where the manuals are hope this helps
Posted on May 14, 2008
escapement
  • 2334 Answers
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Posted on Dec 19, 2008
escapement
  • 2334 Answers
SOURCE: removing links from watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 12, 2009
  • 6 Answers
SOURCE: Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
Posted on May 13, 2009
mcdevito75
  • 1970 Answers
SOURCE: The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Posted on Jul 06, 2010
I need an instruction manual for a fossil fs2919 watch to set the dials
Follow this link and download manual for your watch:
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10
Oct 01, 2010 | Fossil FS2919 Wrist Watch
My chronograph men's watch came without a manual. Where do I find a manual that discusses setting time, cleaning the watch, setting teh date, etc?
Philleo Stark are made by Fossil.<br /> <br /> Go to <a href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</a> and you will see "watch instructions", ckick on this for download of the instructions. They are generic instructions, so you need to scroll down to find the one that looks like yours and download the file.
Aug 26, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
How do I use the chronograph on my watch?...Can't find any instructions online and I don't have the manual. Fossil bq-9165
mcdevito 75 here, Check directly with Fossil on line for the manual, or check with your local watch repair shop.
Jun 16, 2010 | Fossil BQ9165 Wrist Watch
No Manual. How do I set the time and other functions?
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and you will find a list of generic instructions in which you should be able to find a set that suit your watch.
May 04, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
Feb 24, 2009 | Fossil CH2331 Wrist Watch
Fossil blue ch2354 no instructions
Use this link to download users manual for your watch: http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Jan 21, 2009 | Fossil ES9944 Wrist Watch
Apr 04, 2008 | Fossil CH2332 Wrist Watch
Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Aug 29, 2007 | Fossil CH2331 Wrist Watch
Watches Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
