Question about Lands Phones
I cannot get my phone to work..no dial tone when I plug it in to my phone jack. I am attempting to use this newer phone in place of an older phone. Does the phone need to "charge " for a while before
    New Friend:
    Problem Solver:
  • 11 Answers
Yes that should work it helped me.
Posted on Feb 11, 2013
SOURCE: Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Posted on Dec 22, 2007
SOURCE: bought phone EX18560 Series yesterday.
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Posted on Aug 16, 2008
  • 42 Answers
SOURCE: Phone works in one jack but not another
Hi, Looks like either the wiring is slightly different or the jack plug not quite with in the tolerance limit. Can you swap the cables between the units (if they are removeable) to eliminate the cable as well. I would suspect the cable on the new phone! I would also make sure there is no dirt on the connectors on the plug...there are minute grooves where you can see the meatl...sometinmes these get blocked!
Posted on Jan 08, 2009
timthorne911
  • 464 Answers
SOURCE: Satellite won't give me a dial tone
Make sure your phone bill is current, paid in full. If thats not it, then you need to contact your phone company because there is an outage. Give it some time to clear up. If yet even that doesn't fix the problem, It could be your handset. Hope I've helped some :)
Posted on Mar 18, 2009
divatif
  • 39 Answers
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Posted on Mar 20, 2009
Handsets do not ring. Display says line in use
A "Line in Use" message generally means that the phone can't get a dial tone. If all of the handsets/phones for that line are on standby or on hook, you need to check the wiring and incoming connection. First, connect a new RJ-11 cord between the phone and the jack. Check if there is a dial tone with the new cord. At least once, I saw a handset cord used in place of the RJ-11 cable. This combination will give this type of issue. If you have a DSL line, check the filter and replace it if it is inside.
For the rest of the wiring trouble-shooting, I like to check the wiring with a basic corded phone. Check if the test phone gets a dial tone at the first jack. If it does, then your first phone has a problem. If there is no dial tone, try plugging in the test phone at another jack on that extension line. If there is a dial tone, that suggests a problem at the first jack or the wiring to that jack. If you do not have a dial tone or there is no second jack, find your service connection. Open the box and look at the connections. If there is an RJ-11 jack, plug in the test phone. If you have a dial tone here, you have a wiring problem. If there is no RJ-11 jack or no dial tone, contact your telephone company. They can test the phone line and determine if the problem is inside or outside.
If the jack could be faulty, remove the cover plate. Look for any loose wires. There are two types of jacks - keystone and screw terminals. To replace a wire in a keystone jack, you will need a punch-down tool available at most hardware stores in the electrical and wiring aisle. Do not strip the wire; just place it in the correct position and push the wire into place with the tool. For the other type of jack, strip a small section of wire and secure it under the screw. See http://www.lanshack.com/wire_phone_jack.aspx to see the terminal connections.
In many places, the phone company technicians will fix an outside problem for free. This includes a DSL filter in the service box. (There are some phone companies that are trying to force system upgrades and will avoid fixing older wiring.) If the problem is inside but not at the jack, you may want a professional to search for the issue. Your phone company technicians will often do this for a fee.
I hope this helps.
(I've had dial tone issues several times. Some were caused by rodents chewing on the copper wires (underground service). Others were due to work crews digging up the wire. A final outage issue had to do with a lightning strike damaging the DSL filter. With a fiber optic connection, we've had two service issues. The first was just after the installation and involved only one jack. That cable had been dropped during the service upgrade. After locating the RJ-11 cable behind the siding and connecting it to the service box port, the problem was solved. The second required a service call - the fiber optic modem card began to fail and couldn't properly translate the signal. The card was replaced solving all of the problems.)
Nov 18, 2017 | Lands Phones
CS6482 model phone system; (1) base unit, (1) additional phone. Cordless phones are both showing "LIne In Use" but there is no dial tone and neither phone is "in use"
The "Line in Use" message often occurs when there is no dial tone. You'll need to identify where the dial tone problem is coming from. First, check that the base has power and try a new RJ-11 cable between the jack and the base. I like to use a old corded handset phone for additional testing. First plug in a different phone to the jack. Do you have a dial tone? If you do, then the CS6482 has failed.
If there is no dial tone, next try plugging the test phone into a different phone jack, if one is available. If there is a dial tone at another jack and a new cord didn't help at the first jack, then you have a wiring fault at the first jack. This could be in the jack itself or in the wiring to where the phone service comes in. You can fix the jack more easily. Remove the cover plate and determine the type of jack and look for a loose wire. If the wires are attached to screws, you remove the insulation from the end of the conductor and slide it under the appropriate screw. Then tighten the screw onto the wire. For keystone jacks, you'll need a push-down tool to press the wire back into place. The tool is sold in most hardware stores in the electrical aisle. Do not strip the wire before pushing it into place. See http://cablesupply.com/content/47-telephone-connections-and-rj11 to match the wire colors to the correct pin on the jack.
If you do not have a dial tone at another jack or do not have another phone jack in the house to test, find the service box. Open the box and check the connection type. If you find an RJ-11 jack, use your test phone to check for a dial tone. If there is no dial tone or it isn't an RJ-11 jack, contact your telephone company. They can test the phone line and will repair the wires for free if there is outside damage. If the problem is inside the walls, the telephone company will charge a fee to repair the issue. (This may be easier than finding a broken wire in the wall yourself.) Note: some telephone companies are trying to move residential units to newer fiber optic services and do not want to repair the copper wire to the door. This can cause problems with some security phone alerts.
I know at least twice we lost the dial tone on copper wiring after rodents chewed on the wires. That issue hasn't repeated since we were upgraded to fiber. However, during the upgrade, the installer dropped one of the RJ-11 lines behind the siding on the outside wall. Thus one phone was without a dial tone, we found the dangling wire and restored the phone service in seconds. We also lost the dial tone after contractors dug into the underground telephone service up the road from us. That was repaired quickly.
I hope this helps.
Aug 16, 2016 | Lands Phones
I can't get a dial tone on my magic jack phone line.
If restarting doesn't work or the solutions on the web site, you likely need the unit replaced. Personally I like the plus better because it can plug right into the network, account can be transferred. Caution, it likes to run hot when used on network and will need a cool place.
Apr 01, 2014 | magicJack pc to phone, free local & long...
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    Not able to ring out or recieve calls on landline 01772465172
    Is there a dial tone? Have you tried plugging in outside in the NID(phone box) on the side if the house. Take a corded telephone out to the box if it has a test port to plug into. If it does, plug in. If you have a dialtone, then the problems inside with either the station wires or jacks, or other equipment that is plugged into the jacks. Remove all devises from the jacks if trouble is inside and take a known working phone and plug it into a jack. if it works, plug in another device, so on and so on. Be sure to check dial tone, break dial tone by pressing a button. Hang phone up and see if dial tone has returned. If not, then that piece of equipment is bad.
    If no dial tone at the NID, then call in a trouble report of NO DIAL TONE to the telephone company of cable provider. To save money if trouble is inside, purchase the inside wiring maintenance plan and then have them come work on the phone lines. After the service is restored, call and cancel the maintenance. $5 and you're back in service, provided that's all the teleco charges for wiring maintenance.
    Nov 30, 2010 | Lands Phones
    Bought phone EX18560 Series yesterday. floolowed instructions to charge. Today I came home from work, plugged in telephone jack. phone will not turn on. Attempted to re-register (4X's). Led flashes....
    Aug 11, 2008 | Uniden Lands Phones
    No dial tone detected
    It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
    Jul 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
    No Dial Tone on phones or modem
    possible its in your telephone wires, try check it with a liscensed technician of your telephone company.Maybe the wire threads are broken or even worn out.
    Jan 30, 2008 | HP Compaq Presario Media Center SR1750NX...
    if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
    good luck
    wg
    Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
    No dial tone
    Have you tried a known good phone in the jack, if that doesn't work take the phone to the demarc box provided by your phone company and open the door on the box. Under this door locate the mini jack and disconnect it, then plug your known good phone into that jack. If you get no dial tone at this point, then it isn't being provided by the local phone company so it's their trouble. Thank you. Jerry
    Dec 18, 2007 | GE 26998GE1 Cordless Phone
    Lands Phones Logo
    Top Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Lands Phone Expert? Answer questions, earn points and help others
