Question about Whirlpool Washing Machines
Washing machine filled up with cold water but will not work
I have tried all settings and nothing works
  • Whirlpool Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 19, 2013
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
SOURCE: washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Posted on Jun 09, 2008
reg501
  • 413 Answers
SOURCE: Washer fills only with hot water
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Posted on Jun 28, 2008
  • 91 Answers
SOURCE: Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Will not fill or rinse on the cold water setting
sounds like faulty fill solonoid valve,,you can check it with multimeter if your handy...
Oct 03, 2009 | Washing Machines
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
