Question about Car Audio & Video
Shorted no sound - Car Audio & Video
  • 343 Answers
Check the fuse. That is all I can offer with such limited information!
Posted on Jan 20, 2013
My RCA tv turned off in the middle of watching it and now it wont turn back on.red light comes on and tv makes clicking sound but no picture or sound.sounds like it turns off again.
Sounds like the Horizonal Output Transistor Shorted, Also on many RCA sets the Flyback Transformer is bad to go and short the HO Transistor
Oct 09, 2010 | RCA Televison & Video
Sweat got into earbud- sound very faint
That happens because the water and saline solution in the sweat are causing the wires inside the earbud shorting to each other, or shorting to the earbud casing that is grounded.
Let the earbud dry out in few hours or more, if the problem does not go away, then get replacement heaphones, it means that oxide formation on the contacts is causing a short.
Do not use shorted hearphones they can cause damage to the connected device.
Regards.
May 04, 2009 | Shure SE530PTH Professional Headphones
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
KitchenAid KHHS179lss, fried magnitron?
If your magnetron was shorted, the unit would not heat at all.
The sound of a shorted magnetron is usually a loud hum-- but no or very little smell and no smoke.
Components in the High Voltage section -capacitor, diode- give problems if they short out.
Feb 17, 2009 | KitchenAid KHHS179LSS Convection /...
My system is not showing any error message or post message in monitor.
beeping sounds, light flasing when you turm on machine, machine will not even turn on, mute sounds how many and long or short sounds or mix sounds, same witrh lights short or long light signals.
or more information than you are giving me
rod
Feb 01, 2009 | Computers & Internet
Mother baord beep sounds
Which model? Are the beeps 1 long, 2 short, 1 short, or just continuously short? Continuously = RAM needs checked and/or replaced (you can download either Memtest or the Microsoft Memory Diagnostics CD's to check it) 1 long and 2 short or 1 long, 3 short = VGA card needs checked
May 29, 2008 | Intel Motherboard
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
No picture and no sound,
Something shorted and shut your set down. Most likely the high voltage transformer shorted which also shorted the horizontal output transistor. Stargazer
Aug 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
