Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Model # ED2SHAXMB10, iCE MAKER HAS ICE,WILL NOT DUMP,MAY BE JAMBED, CANT BREAK LOOSE ?????
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Here is the service manual for the ice maker.
Posted on Jan 20, 2013
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
Posted on May 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Model ED2CHOXK005 Whirlpool refrigerator with ice
The problem is most likely your water control valve for the ice maker. There are 2 one for ice maker and the other is for the dispenser. Fill your ice maker with tap water. Let it freeze and if it dumps and does not refill then the water control valve part number 2188542 let me know if you need more help, Sea Breeze
Posted on Aug 19, 2009
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
WHIRLPOOL REFRIGERATOR MODEL ED2SHAXMB10 ICE MAKER NOT WORKING
Here is the ice maker service manual for that unit. Go to the trouble shooting section and check the test points. Post back the results.
Jan 19, 2013 | Whirlpool Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
Ice maker not dumping...the ice is freezing but not emptying.
Make sure the arm is down on the ice maker. There is a heating element that warms the ice tray slightly so it can break the ice loose and dump. If the element is bad it would be best to buy a new ice maker. They run from 68 dollars and up. good luck
Aug 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit workingon kitchenaid side by side bowfront
check to make sure yr getting water to inside of ice maker if you are then replace the icemaker you can order them from marcone or allbrands appliance
May 16, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Kenmore side by side model #56829 ice won't dump out of ice maker
Your heater in your icemaker could be out. That's what melts the ice to break loose from the ice maker. It may be less expensive to replace the whole icemaker.
Aug 14, 2009 | Refrigerators
Ice Make will not Dump into Bucket
The arm that drives the ice out of the freezer tray is driven by a small motor in the front of the ice maker. The motor has a small gear that drives the larger gear keyed to the front of this arm. If the ice is ever allowed to thaw and re-freeze the driven gear can break one or more teeth off affecting the operation of the ice cube removal. None of the parts of the ice maker are available separately. However these parts are easily repaired with super glue or epoxy. When re-installing the drive arm it must be located with the drive fingers horizontal.
Feb 28, 2009 | GE Refrigerators
Ice maker jambed-now no water
The ice maker must be re-primed with water to sense frozen ice in the tray, dump, and refill. Use a cup or glass to manually pour the water into the tray just below the top of the blades. It should freeze, dump, and refill.
May 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
