Question about Cameras
LG235C battery cover won't snap on and stay
Instructions say align and push down, I hear a snap but cover falls off. On Amazon reviews, this is listed as a frequent issue.
    Genius:
  • Cameras Master
  • 1,019 Answers
Return it a buy something better with your money, these are made in China and very poor quality. Too many customer complaints.
Posted on Jan 26, 2013
3 Suggested Answers
t0pc4t
  • 132 Answers
SOURCE: Battery Cover latch is broken
what camera is it ??
Due to the frequency of changing batteries on my camera, I have 'dremelled' a very fin pin hole through teh side of the case, and into the battery holder.
Then opened the case hole up to accept a small screw, then allowed the scre to tap itself into the battery housing.
Small phillips screw nice and flush on the case now.
Works for me, and could save you money and tape !!
Posted on Aug 15, 2008
SOURCE: i'm having issues getting my
The problem is most likely with the micro switch in the Compact Flash door. Try using a Memory Stick and the problem will not likely appear.
Posted on Jun 02, 2011
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
What causes an acer aspire e14 gives memory error messages on start up
Try this solution... Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. Align the keyed (notched) edge of the memory module with the keyed area in the expansion slot. Insert the memory module into the slot at a 45-degree angle until it is seated.
  7. Push the front edge of the memory module down until the retention clips snap into place.
  8. After reseating the memory module, replace the memory expansion cover and then replace the screw.
Step 3 - Replace the battery
  1. Insert the battery into the notebook.
  2. Push the battery into the base enclosure until you hear a click.
  3. Connect the AC adapter and turn on the notebook.
Sep 05, 2014 | Computers & Internet
The pressure foot won't go all the way down
take off side plate and loosen pressure ft screw . it should snap down. make sure the foot stays align wit the needle. u want the foot slot with needle in ctr.
Oct 20, 2012 | Juki TL-98Q
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
Cover won't go on.round metal strip won't fit on round spindle that turns chain.E-235.Do I need the break bar?It doesn't line up either. DB
Sounds like the chain brake was set when you took the cover off. You need to disengage the chain brake (release it) so the round spindle will fit inside. Look for the two parts (one on cover, one on saw) that match up at the base of the chain brake. You won't be able to fit the whole cover on, but if you can line up where the metal triangular gear engages the chain brake, you can give it a snap to disengage it. What I have done in the past is to line up the two parts and push down on the top of the cover where they meet so as much of the gear is in the chain brake release as possible ( I put a knee on it ) and then give a snap to release it. Be careful though, because the cover part is plastic and you don't want to strip that part of the chain brake assembly. Good luck.
Sep 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
When i push the power button and let go it turns off and won't stay on. what might be the problem.
Sorry to hear you're having difficulties with your DC27. In case you haven't already tried this, make sure you press down firmly on the power switch when turning the cleaner on. If the switch still won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 20, 2011 | Dyson DC27 Bagless Upright Vacuum
I cannot replace the back of a timex 1854 watch. I replaced the battery but the back won't click on
I used a four inch "C" clamp and a large washer about diameter of back, to get my Timex back snapped back on. Place the watch face side down on a flat surface cushioning the crystal with soft rubbery material like shelf liner or anti skid material used under rugs (the kind used to also line tool chest drawers - black). Place the washer between the watch back plate and the "C" clamp screw plate. Align the back plate of the Timex as evenly on watch as possible while gradually tightening the "C" clamp. Keep turning down the "C" clamp ever so slowly until you hear the plate snap back on.
Jun 28, 2011 | Watches
I replaced new cartridge but show up 'insert cartridge' repeatly. i insert cartridge.but again again repeat show up 'insert cartridge' what is problem? please help me.
  1. Push down on the cartridge to release it from the carriage, and then lift it up and out of the product. Figure 2: Remove the old cartridge c01747836.gif illustration of removing the old cartridge
  2. Remove the new cartridge from its packaging, and then pull the pink tab to remove the clear protective tape. Figure 3: Prepare new cartridge c01745262.gif illustration of preparing a new cartridge CAUTION: Do not touch the copper-colored contacts or re-tape the cartridge. Figure 4: Do not touch contacts c01746332.gif warning not to touch the cartridge contacts
  3. Hold the cartridge with the label on top. Figure 5: Label on top c01668109.gif illustration of holding the cartridge with label on top
  4. With the copper-colored contacts facing into the carriage, insert the cartridge into the carriage at upward angle. Push the cartridge up, and then into the carriage until it snaps into place. Figure 6: Install cartridge c01745263.gif 1 - Insert cartridge 2 - Push cartridge up 3 - Push cartridge in illustration of install the cartridge
    NOTE: If the cartridge moves loosely in the carriage, it has not clicked into place. Repeat this step.
  5. Close the cartridge compartment cover, and then the control panel.
Step three: Align the cartridge
  1. Press the Start button (c01371053.gif ) on the product control panel.
  2. Press 1 to indicate you installed a new cartridge. The product prints an alignment page and 06 [01-11] displays on the control panel. Figure 7: Alignment page prints c01745264.gif illustration of alignment page printing
  3. Review the alignment page, and then select the number under the straightest line.
  4. Press that number on the keypad, and then press the OK button (c01335940.jpg ).
May 21, 2011 | HEWLETT-PACKARD HP 2140 Fax
Where can replacement parts be brought for the Crayola Magnetic Double Easel
n order to make the art trays stay on the easel (several people have complained that they easily fall off), you have to reach behind (inside) the easel and snap them on. You don't just sit them on; they snap in place. Do this and they won't keep falling off. : ) if thats the problem....there are no replacement parts...
May 18, 2011 | Crayola Toys
DSC-S40 , my camera wotn switch mode.
If you opened and unable to find the switch, then the switch might be snapped, or the sw slider was not aligned to the sw itself. you can find it by aligning the sw slider of the back cover to the main board, its a very small switch soldered on the board near the upper portion of the LCD panel. If you find it, slide it to leftmost, at the same time, move also to the leftmost the sw slider at the back cover. Assemble it carefully, thanks
Aug 13, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Open Questions:
Cameras Logo
140 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
