Question about Kitchen Ranges
Technika oven range - model B5OSTIP/1 need help with what the dials mean?
Require help with what the dials mean on this model
2 Suggested Answers
  • 93 Answers
SOURCE: i have maytag range model
F1-1 : this indicate runaway cook upper oven.
Solution is to check oven temperature sensor,replace if necessary.
F3-1:It indicate oven temperature sensor, upper oven. You need to replace your temperature sensor.
If you need the part # let me know.
Posted on Jul 26, 2008
Technika oven manual - mod B50STIP/1
I have a Technika B50 STIP /1 Oven and the Oven Function Selections have warn off. I mostly use the conventional cooking ) at 7.00 oclock on the dial) I cannot remember what is on the dial at 5.00 oclock? as it has worn away.
Help please
Liz
Aug 05, 2012 | Ovens
I need an operating Manual for a TECHNIKA Oven Range - Model GHE09TD
The operation manual for TECHNIKA Oven Range - Model GHE09TD is not freely available.
To avail this manual either you can contact to the manufacturer or you can make your order at this link: " http://www.2instructions.com/search.php?cmarque=TECHNIKA&modele=GHE09TD".
Hope this will help you. Good Luck.
Aug 03, 2011 | Microwave Ovens
My kenmore electric range model 790 is displaying a F10 code which i believe it means it's overheating. can you help with this problem
Frigidaire stove
(F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive.
Feb 04, 2010 | Kitchen Ranges
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
Technik range oven
You said, you have a key symbol that's just showed up near the digital clock, and what it seems to mean is that the ovens are 'locked in some way. They won't heat up. When we turn the dials the red light doesn't come on and we cant hear the fan. There is a reset button on there but it doesn't get rid of the key symbol. I think someone leaned on the buttons yesterday and have inadvertently locked something! Please help! We can't find the manual.
1.Try holding down the reset button for 5 seconds!
2.Then if needed turn off the power from the breaker for 5minutes and see if this resets the system.
3. Send me the Model # and I will find you a user manual too!
Waiting for your response. If you can't find the model # , it will be on a white or silver sticker in the door Jam of the range OR the storage drawer below!
Huuum
Please remember to leave a rating!
Oct 12, 2008 | Kitchen Ranges
I have maytag range model mer6770acw it give me codes f1-1 and f3-1 after 10 to 15 minths of using the oven what is that codes means and what i should do before calling the service tech. thanks
Jul 26, 2008 | Maytag Kitchen Ranges
Grill element stopped working in the middle of grilling roast pork. Blown element vs fuse - don't know where to find fuse box on oven. How do you tell if the element has blown? Is it easily repairable or...
there is no fuse actually in the oven
take rear panel off oven and use a multimeter to check continuity across the grill element. can also be the grill regulator if fitted
Jun 29, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
