Wondering if its the color wheel? Maybe something more because the alignment bars are curved. The picture is horribly ghosted
  • Televison & ... Master
  • 15,557 Answers
What is the make and model?
Posted on Jan 19, 2013
Testimonial: "43fdxo1b. Vok042629"
  • 6 more comments
  • josh hall Jan 19, 2013
    Hitachi ultrascan hd I'd have to look for more details if u need?
  • Brad Brown Jan 19, 2013
    The kit for your set is probably part#X480301
    What is that? Can u give me the link where I can find more info please?
    Without an exact model number it is hard to say but the issue appears to be that the television has a known issue with chips and other parts.
    43fdx01b
    Not sure if that is it pretty sure tho lol
    http://www.tvrepairkits.com/xcart/43fdx0...
    Your awesome!!!!
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
I have a Sony Rear projection tv, about 7 yrs. The screen is now showing double ghost images in color and curving at the sides. I read advice on "calibrating" using the owners manual (which I...
hi,
u didn't mentioned any thing about u r tv. is it a dlp type one or crt type.if t is crt type then change the crt base of all the three guns. may be ur problem will be solved
ok
Dec 31, 2010 | Televison & Video
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
We have a Hitachi projection tv maybe 54" that worked fine yesterday but today has shadowing/ghosting in pink & green. Wondering if there's something easy to try to fix? If not, is it worth getting it...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 03, 2010 | Philips 60PP9352 60" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
The colors on my tv have separated, red, blue and green.
This a convergence problem. You maybe able to correct "electronically" by using the remote control and menu setup options. If you cant get where you need to go via remote control. A profession tweak may be needed inside the tv to phyiscally align the colors. good luck
Jun 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
Covergence Problem
What exactly are you seeing on the screen? If one of the colors is only slightly off, you should be able to correct it with the standard menu. If one or more of the colors has suddenly taken a dramatic shift, and is curved inward at a side, it means that one of your convergence output IC's has burned out. You should not attempt to realign the convergence if this happens because you will only be messing up all the settings, and when the new IC is installed, the picture will still be out of alignment.
Aug 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
