Question about Fujitsu AMILO Computers & Internet
Speed gear v7.2 reg code - AMILO Fujitsu Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
Http://serialnumber.in/search/speed+gear+v7.2+registration+key
Posted on Jan 19, 2013
Will these 2002 ford ranger transfer cases interchange,mine is reg cab 4x4 standard 5 speed 5T13-54-000-038[1L547A195CE]other Access cab 4x4 Automatic 6C13-54-000-037 [1L54-7A195-CC] outsides are same
ONLY use the identical item as the original equipment.( Don't waste your time looking at other products). If you use a different unit you will have significant issues.
Nov 29, 2015 | 2002 Ford Ranger Regular Cab
Vito 1.9 manual second gear will not select
Sounds like 2nd gear synchro prob but check gear change cable adjustment first
Apr 15, 2014 | Mercedes-Benz C-Class Cars & Trucks
Nissan Primera 1.8 V reg. EML on perm and flashes especially on start up, wont exceed 4k revs, is very jumpy in 1/2/3 rd gear, hills very slow.. 40-50 at best, sparks replaced and coil pack changed......
The codes need to be read. This will point you in the right direction. But just guessing , it sounds like a throttle position sensor. But there are other sensors that could do this. Again have the codes read. Most parts stores do this for free.
Jun 22, 2011 | 2005 Nissan Titan
My 2000 Sephia will only shift gears manually from 1,2, then to drive. I get a code PO734. How do I fix and or slove this problem?
This is what your codes mean:
Trouble Code-P0734 (A/T Additional Gear Ratio Error In Fourth Gear)
Trouble Code Conditions:
Vehicle driven to a speed of 4-37 mph at more than 500 rpm, gear selector in 4th Gear in Drive, and the PCM detected too much difference in the engine speed and output shaft speed.
Possible Causes:
  • Customer may complain of intermittent 4th gear operation
  • O/D and 2/4 pressures less than 75 psi
  • O/D or 2/4 clutch volume indexes out of specification
  • O/D accumulator seals are damaged
  • Transmission enters "limp in" mode running in 4th gear
Trouble Code-P0735 (A/T Gear Ratio Error Fourth Prime)
Vehicle driven any forward Gear, and the TCM detected the ratio of the Input speed to the Output Speed did not match the current Gear Ratio (this test can take up to 5 minutes).
Possible Causes:
  • Related Gear Ratio trouble codes may be stored (note that some of these Gear Ratio trouble codes may be intermittent)
  • Transmission has internal problems or damage present
You have a transmission problem.Hope this helps, James Booth
May 17, 2011 | Kia Sephia Cars & Trucks
Code po734, po735
Possible Causes:
Possible Causes:
Jan 17, 2011 | 2003 Dodge Durango
Lack of speed
You could try changing the sprocket sizes. This will change the gearing.if you change the size to give you more top speed tho, you will lose acceleration. have a look at www.chaingang.com.au .They have a calculator on there that will help you work out your final speeds etc.
Dec 12, 2008 | 2006 Honda CBR 125 R
V Reg Chrysler (auto). My car is revving too much and it doesn't always change up to the fourth gear. Could it be that I need to change the air filter or is it something more serious ie. I need to get a...
Have the vehicle scanned for trouble codes first.It is possible that one of the speed sensors mounted on the outside of the trans is not working properly.A thorough diagnosis is in order before pronouncing the trans bad or internally damaged,as it could cost upwards of $3000.
Jul 31, 2008 | Chrysler Voyager Cars & Trucks
Audi aotomatic A4 1800 V Reg. Gearbox
have the garage do a driveability diagnostic interfacing with the gearbox and watch for torqe converter lock up..as well as gear and speed changes tps values...
Jun 18, 2008 | 2000 Audi A4
Computers & Internet Logo
668 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
