Question about Denon AVR-2313CI
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
I am not getting any video when I connect via single hdmi cable. Setup. Ps3 to receiver. Receiver to tv. Both via hdmi. I cannot connect directly to tv. Only one hdmi in. Other ports not accessible
    Genius:
  • Denon Master
  • 1,342 Answers
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Posted on May 11, 2014
When i try and play online (uncharted 2) im connected see all of my friends but when i try to connect to the uncharted server it takes a long time then i see the connection bar moving, then i get an error...
You need to do a reset on the modem and router by pressing the reset button with a ball point pen and if you don't see a reset button unplug both for 20seconds. Don't hold the reset button in for longer than 5seconds or you will have to reconfigure your modem and router VIA your PC.
Sep 14, 2011 | Sony Playstation 3 (PS3) Console
Just bought a 46" Samsung
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
This is a site where you can download a manual. I'm not familiar with Denen however, you should be able to go out of satellite receiver(HDMI) to your receiver input(tv/sat) then to your HDMI input on tv. Your receiver might show video and sound through another port of receivers options, ie; video 1, video 2, etc. Check all putput options for your picture and sound. Hope this helps.
Mar 04, 2011 | Denon AVR588 Receiver
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Hdmi not working
Please rephrase you get an "ant screen"?
Does the sound work? What is your hdmi video output device?
At any rate, you can also try this quick fix. In the setup menu go to Source Select. Make sure these settngs are right:
Assign>HDMI = HDMI 1 - 4 (depending on device)
Input Mode>Input Mode = Auto
Decod Mode>Decode Moe = Auto
Other>Video Convert = On
Set this for sources (devices) you have connected to the hdmi.
Jan 03, 2009 | Denon AVR-4308CI Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
Denon AVR-2313CI Logo
140 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
