Question about Dragonplay Live Holdem Poker Pro
Since they changed there screen...i cant see all my screen...cant bet or any thing ...how do i fix it
It keeps on crashing and i cant access the settings
You most likely have a virus, scan your hard drive with a rescue disk. I would recommend both AVG and Kasperski. Use both of those. After that you will have to fix a lot of things. The properties have most likely change on your operating system if you cannot see your desktop icons after the scan. From that point your best bet is to hit alt, ctrl, delete all at the same time which will bring up your task manager and allow you to access and fix your problems
Nov 02, 2013 | Computers & Internet
I have a single vertical blue line on my 50CT Libretto screen. It does not show on an external monitor. Any ideas what's causing the blue line if it can be fixed? Thanks Mike H
Just a bad screen. There's not a cost-effectve fix for these things due to the age of this laptop and on top of that, these screens were incredibly rare even when they were first sold. If you must replace it, then your best bet would be to hunt down a whole unit (eBay would be your best bet) - it might take a while but your target price should not be over $20 delivered. That'd be your best bet.
Sep 08, 2011 | Toshiba Libretto 50CT Notebook
I have two durabrand dvd screens that hav a black spot in both is there anyway to fix or change the screen?
Well there is a possibility you could change the screens out if you are good at that sort of thing best bet would be to type in model of dvd player on ebay and look for them. I doubt you would be able to get them from the factory and if you could would probably be better to just flat out replace them. But Ebay has all those types of things I would check there first~
Dont Forget to VOTE~ :)
Hope it works out for you~
Jun 07, 2011 | Car Audio & Video
My mac screen is in negative and it still doesnt change when i press control option command 8 (it just makes the screen lighter). the colors are off unless i press the dashboard button but its annoying...
Unfortunately with any kind of liquid damage all bets are off. You can change one thing and it may or may not fix the issue. And after some time you might have a completely different issue. You're smart thing is to cut your losses and get a new computer. Remember to backup your system before you lose everything. To be quite honest I'm surprised still working. Good luck.
Oct 19, 2010 | Apple iBook Mac Notebook
Cant see picture clear unless looking at eye level
I think you are correct. The standard def Tv is just poorly set up.
Look at your manual and see what the specs are for off angle viewing. I bet that the limit is right around 30-45 degrees. Which is not unusual for older low def screens.
The fix, unfortunately, is to buy a newer unit with better specs. The nice thing is....the prices are way down.
Feb 08, 2010 | Dynex 480i 27" TV
The screen is all black
this sounds like a problem with the screen only. best idea is to go on sony.com.au and get info on sending it to them where they will fix it proffessionally, and give it a service. best bet. please rate
Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
How to fix blinking of HP L2208w monitor
well , did you read the rules on the monitor for
resolution? 1680 x 1050 at 60 Hz
and that this OLD MON. has CCFF back lamps that can fail in 20,000 hours use! its not LED so they fail early.
dim , blink or just go dead. all do that and fast....
why not upgrade, to LED< be best. for sure.
no CCFL has future, now, they are too old now.
and spending $50 to fix a old CCFL mon.
when we can buy a new one for $50 , is well, good money after bad.
does the monitor run on any other PC OK? I bet not.
the only clue for sumptoms above is BLINK
I cant see that do that so can tell you any thing....
shine flash light in the face screen yet
to see if BLINK is , Backlight dead, or DATA DEAD.?
Sep 18, 2017 | HP L2208w LCD Monitor
1)i cant connect to the interface of Thomson 585 v7... 2)i cant connect to the internet...it says that my pc cant get an ip
if you cant get an ip best thing o try is to look at the bottom right of the screen on the task bar click on the two computers thing click on the support tab and repair ip if that dont work calling your internet provider would be best bet they might be having issues
Dec 04, 2008 | Computers & Internet
Acer aspire 5100 - screen is turned off, cant turn it back on
The bios beep codes indicate the video card is not working, so you won't see anything on the screen.
Your video card is either dead, or is not contacting the board correctly.
If you are keen to open it up I will offer instructions to assist you. But in reality, your safest bet is to take it to a laptop shop and get them to do it. There are a lot of tiny screws in these things.
Apr 17, 2008 | Acer Aspire 5100 Notebook
I have the Mororola SLVR L72
well, thats the bad thing about unlocking phones, ur best bet is to go to ur Service provider store and ask hem for help, they ll be able to tell u if u will be able to fix this issue but i doubt it.
Feb 10, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Dragonplay Live Holdem Poker Pro Logo
90 people viewed this question
Top Dragonplay Apps Experts
Brett Duxbury
Brett Duxbury
Are you a Dragonplay App Expert? Answer questions, earn points and help others
