Question about JVC SELECT HD-55G466 Rear Projection Television Replacement Lamp RPTV
Jvc tv will not shut off
Sometimes when I try to shut off tv the blue power light stays on. I can hear fan is still running and the screen is a dark blue-black color. It's like it is hung, even if I try to shut off manually it won't shut down. I have to unplug it completely. This happens one out of three times???? Also when I try to turn on tv the screen flashes static for 2 seconds and then goes completely black.....I have to shut down and try to turn on again? If anyone knows how to correct, please advise.
smilemaker
  • 790 Answers
SOURCE: "Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Posted on Dec 23, 2007
SOURCE: JVC HD-56G887 wont turn on
Your TVneeds to be serviced by a JVC authorized service center.
Posted on May 11, 2008
SOURCE: JVC 56FN97
Make sure the bulb is seated properly in it's hole. It has to be an exact fit or it won't work.
Posted on Oct 16, 2008
SOURCE: my jvc hd-56g886
replace the lamp
Posted on Nov 04, 2008
SOURCE: 52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Posted on Jan 30, 2009
Hi there I have a jvc tv 'LT-42X788' when I power on the cbc sign comes on I here a click and screen shuts of there's a blue light that came on when I power on it stays on any help thanks
@Thomas Scissons
"JVC LT-42X788 display fault..."
Hi Thomas.
Please pick one:
Power supply board (possibly a blown capacitor):
A TV-tech can repair at reasonable cost, less than a new set.
The main board itself has a control / display section fault:
The screen / panel is shot:
Beyond economical repair - renew set.
Hope this helps.
Clive.
Oct 16, 2017 | JVC Televison & Video
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
The blue & red lights on my JVC HD-56G787 tv are blinking alternately
Or the problem could actually be a power supply failure
Nov 08, 2013 | JVC HD-56G787 Television
I turn the Tv on and after 2 or 3 minutes the tv turn off and the blue light stay on and the red light start blinking
Most likely the fan in the rear has gone bad and the lamp is overheating and the system identifies this and shuts it down. Check to see if cooling fan is activating on power up.
Jan 12, 2011 | JVC AV-48P775 48" HDTV
Model: HD - Z70RF7 projection TV Lamp has blown. I have replaced with brand new lamp and now get rapidly flashing orange lamp light on front of TV, blue power light is solid and not...
Tv turn on now,hear alots of clickings too?Yes.Check the Ballast board,this board might be dead too.The ballast board job is,just it to help to ignite the projection lamp.
Oct 28, 2010 | JVC Televison & Video
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Blinking red power light - set will not turn on
Were the pale blue lines real thin in a slight diagonal from bottom to top of your screen? If so you either have a bad component in the blue drive, Blue CRT socket or your Blue CRT is shorted.Try removing the blue CRT socket and trying to power up your set for a moment without the blue socket attached to the tube. Be sure the CRT socket doesn't touch any components when you try this. Let me know if the set starts up without the blue.
Jan 23, 2008 | Televison & Video
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Sep 25, 2007 | JVC HD-56G886 56" Rear Projection HDTV
JVC SELECT HD-55G466 Rear Projection Television Replacement Lamp RPTV Logo
18 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
