Lg wf 801 top load washer won't fill .take water line off cold inlet & put on hot inlet will fill . put back on cold inlet for rinse cycle all ok .
  • Washing Mach... Master
  • 17,129 Answers
Question was answered earlier. Thank you
Posted on Jan 19, 2013
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Posted on Apr 12, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
After 2 yrs. the cold/cold selection doesn't work at all but the other selections give me hot h2o only. Also, rinse cycles just stopped working!
Your water inlet valve has 2 electric coils on it. One for hot --one for cold. The cold is probably bad. Most newer machines use COLD rinse only so if no cold fill it just stops in the rinse cycle. Replace the inlet valve which is the part on the machine back the hoses hook to.
Mar 23, 2015 | Admiral AW22 Top Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Lg wf 801 won't fill
Yes , It can be related to the control board, but first of all please make sure that there is good water flows in both the inlets, check the flow after the valve , ensure that the inlet filters are not clogged and check all the connections from the harness to the valve and panel
Jan 19, 2013 | LG WM Washing Machines
Whirlpool Ultimate Care II LSQ9549L top load washer -- hot water okay at inlet on back of unit, but won't fill tub. Is it a valve or a clogged line inside?
Most likey a bad water valve. You can replace it with just a few screws and a pair of pliers for the hose. You can test by swicting around hoses and the plugs on valve if you'd like to test it then try the machine on cold wash(it should be hot). While you switch them inspect the screens for rust and any clogging. Good Luck, Mastatech
Aug 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
NO WATER INTAKE WHILE RINSE OPTION IS ON
It sound like the cold water inlet valve is faulty, the rinse cycle uses only cold water, and the water in the 'wash' cycle is probably hot.You need a new inlet valve, which on your machine is probably a double hot/cold unit.If you can't get a new inlet valve, a handyman/electrician may be able to change the wiring to use the 'hot' inlet valve for cold water which will allow the machine to wash, and rinse, using cold water through the hot valve..Tikka?...Good luck...Nomess
Jun 01, 2010 | LG WFT1071TP Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Cold water does not fill for the wash cycle but will fill for the rinse cycle
just a guess make sure hot water line goes to hot water inlet look close there is a difference and cold to cold cold will be blue
Apr 12, 2010 | General Electric WHDSR316G Top Load Washer
Washer only fills with hot water
Probably a bad water inlet valve. To verify, you would have to check continuity at the valve.
http://tclaundryrepair.com/home
Feb 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
215 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
