Question about GE Refrigerators
Que compresor lleva el REFRI GE MODELO TBX09YBM
SOURCE: no enfria el aire acondicionado, sin entra el
De que equipo estamos hablando? Un auto, aire acondicionado, nevera o refrigerador. Dejeme saber quiza lo pueda ayudar.
Israel
noenfria.com
Posted on Jul 29, 2009
Raditronic
  • 196 Answers
SOURCE: no deja grabar pues dice que el disco no es grvable
trata con otro disco CD-R o CD+R, si el que tienes es CD+R pues trata con el CD_R
Posted on Apr 30, 2010
heatman101
  • 43501 Answers
SOURCE: Tengo un frigorifico Magic chef
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Testimonial: "Gracias, el problema está solucionado"
guru_fixya
  • 944 Answers
SOURCE: El refrigerador dejo de enfriar.
This problem could arise due to various reasons.
1)Start relay is bad.
2)Over load to the compressor.
3)Dirty condenser,should clean it.
4)condenser fan motor not running.
5)compressor not running.
To check the compressor properly you should test it with an amp meter.if the compressor is drawing too much current, this may be why it is shutting off some relays will be easy to notice they are broken with them,they may be burnt.Replace it.Check if the windings in the compressor gives reading for each terminal.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
ZJLimited
  • 17970 Answers
SOURCE: desconectaron la Vateria de mi
Ante la ausencia del manual del propietario y de la posesion del codigo de desbloqueo, necesariamente, Usted tiene que visitar a su representante Honda, demostrandole que el vehiculo es de su propiedad, para poder obtener el codigo de desbloqueo correcto. A veces este servicio es cobrado. tenga en cuenta que este codigo es unico, y que nadie se lo puede ofrecer por Internet.
Espero que esta respuesta le sea de utilidad (recuerde calificar la ayuda).
Posted on Oct 11, 2010
Testimonial: "muchas gracias, ya lo consulte en la agncia y me dijeron lo mismo."
Donde esta el fusible de compresor ac
Me puede decir la marca y modelo del coche que tienes y te dir? la ubicaci?n de la caja de fusibles. La mayor?a de los coches de la caja de fusibles interior est? debajo del tablero del lado del pasajero. Si usted tiene el manual del propietario, y sabes lo que no funciona, que le dir? lo que se fusionan para tirar.
Si usted no tiene el manual del usuario, se puede tirar del fusible a la vez y mirarlos. Un fusible fundido tendr? una rotura en el cable que se puede ver con sus ojos. Buena suerte. He utilizado Google traductor para el espa?ol, as? que espero que esto no es tan malo.
Apr 14, 2016 | AC Cars & Trucks
Tengo un aire portatil continental modelo CE PAC 10651 y se le partio el aspa que lleva en la parte de atras. donde puedo adquirir el repuesto por internet o hay un proveedor en Venezuela al cual pueda...
i no pudo localizar a ning?n proveedor parte de Venezuela. y, ¿puedo localizar una tienda que te pueda ayudar. si usted todav?a tiene el manual del usuario, buscar un n?mero de tel?fono de contacto, que puede llamar.
Aug 17, 2011 | Continental Dublin Series 13,000 BTU...
Deseo conoser con exactitud los tipos de puertos o conexiones que lleva el computador hp pavillon 1000 grasias
2 puertos de salida de audio para aud?fonos/bocinas
1 puerto de entrada de audio para micr?fono/l?nea
3 puertos USB
1 puerto VGA (monitor, proyector)
1 puerto de expansi?n
1 puerto RJ-45 (red)
1 puerto RJ-11 (modem)
1 bah?a PC Card
1 puerto S-Video *depende del modelo*
1 Lector de memorias 6-en1 *depende del modelo*
1 puerto 1394 (firewire) *depende del modelo*
May 04, 2011 | HP Pavilion dv1000 Notebook
Tengo una refrigeradora GE modelo gss25qta,el motor esta funcionando y no enfria que puede ser gracias
El compresor y los ventiladores deben todo estar prendido.
Si no entonces el control es malo.
Su PSS Service Manual en gringo
More here
Gracias por usar Fixya
Jan 07, 2011 | Heating & Cooling
Que marca y tipo de aceite se debe cambiar al motor que lleva la toyota previa 1991 y que cantidad lleva
hola, porque el toyota previa 91, tiene un tanque enfrente que al parecer es para el aceite de motor. pero bajo el aciento tiene otro que tambien indica aceite de motor. nadie me despeja esa duda y el tanque esta seco, pero el nivel de aceite de abajo me marca correcto. que hago? ayudenmeeee!
Oct 06, 2010 | 1992 Toyota Previa
Cuantos litros de aceite y que tipo de aceite lleva una jeep patriot 2008 4 cilindros gasolina y donde se encuentra su filtro de aceite y gasolina
hola que tal el filtro de gasolina lo traen arriba de una tolva que se encuentra exactamente por las ruedas delanteras ( abajo del motor) quitas esa tolva y es de lo mas facil cambiar el filtro y el aceite,, el de gasolina si esta un poco mas complicado pues esta dentro del tanque. lleva aceite del que quieras un 20w50 estaria bien depende de que kilometraje lleve pero mejor ponle un sintentico...
Sep 18, 2010 | 2008 Jeep Patriot
Tengo un frigorifico Magic chef modelo GC20B 7C3EV. el compresor esta funcionado normal, pero no llega frio al refrigerador y el congelador se esta descongelado, parece que no hay circulación...
heatman101
Sep 08, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
ICOM- ICV-100 no transmite y no encuentro el manual de servicio
For a service manual, try Googling (Icom)(ICV-100)(manual) without parens.
Jul 11, 2017 | Audio Players & Recorders
RAFRIGERADOR SAMSUNG SRS20DTD
Estoy en los Estados Unidos, pero quisiera ayudar. Llamé Samsung, pero no tenían ninguìn Info en esta unidad extranjera. Llame por favor:
A CENTRAL TECNICA (SERIN)
CLL 70 # 16 - 43 BOGOTA, CUNDINAMARCA 6001272
B HOME SERVICE DE COLOMBIA LTDA
Cll 24 No 68H - 24 sur BOGOTA, CUNDINAMARCA 6001272
C SERVICE SOLUTION E.U.
AV CLL 116 NO 70C-28 BR. POTOSI BOGOTA, CUNDINAMARCA 6001272
Jul 17, 2008 | Samsung SRS20DTD Side by Side Refrigerator
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
