Question about LG WM-2277HW Front Load Washer
Replace brushes lg motor - LG WM-2277HW Front Load Washer
  • LG Master
  • 17,129 Answers
Please check this link for tips: motor brushes
Posted on Jan 19, 2013
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
The washmachine stop turning the drum, I opened it and struggled to take out the drum to see what the problem is
If there's no mechanicl issue then first thing I would check is the motor. Could be burnt out and if it has carbon brushes which wear out and eventually they simply lose connection tp the armature so no power can be delivered to the motor. Some brands do not supply brushes, new mmotor only. I think LG may be one of these/
Mar 23, 2013 | LG Washing Machines
.My LG washing machine fills
If it fills and empties, that Eliminates The Pump. If no Spin Of the Actual drum, Could Be Belt-Stretched/Snapped. Motor brushes Worn. Or A Problem With the logic board Controller Panel.
Go for The belt/Motor brushes first.
Mike.
Jun 02, 2011 | LG Washing Machines
Hi LG WD 1433rd wont spin up to speed. Have replaced hall sensor as a LE code came up. What do I replace next??
'won't spin up to speed'- does that mean that it stays running at the normal slow speed? If so it could be motor OR control board.
If it is just struggling then it does sound as if the motor requires replacement, particularly noticeable when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
The choice of course is entirely up to you- but do not forget that it is not an uncommon fault, especially if the washer is not exactly new. Others I have given this advice to have chosen new brushes and I don't blame them!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 02, 2011 | LG WD14311RD Front Load Washer / Dryer
Brush will not rotate and the belt is on,is there a motor just for the the brush?
No there is not, if the main motor is turning then the problem is that the brush is jammed with debris. You need to remove the brush and clean out the debris or replace the brush assembly.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Eureka 431A Optima Bagless Upright Vacuum
The barrel in our LG front loading WD won't turn.
Carbon Brushes on the motor worn down
Pulley loose on the motor or Drum Pulley
Motor control pcb failing to supply enough power to activate the motor
Take your pick !!
Sep 28, 2009 | LG Washing Machines
Premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
Fitting brushes
just replace the motor. the brushes are inside the motor and if you dont know what you're doing you will end up replacing the motor anyway. if your machine agitates but does not spin its not the motor, be more specific about make and model and more specific info on the problem and we might be able to help
Sep 24, 2007 | LG WM2688H Front Load Washer
LG WM-2277HW Front Load Washer Logo
29 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
