Question about Motorola Mobility RAZR V3
Camera Problems I just got a RAZOR V3 and everytime i try to use the camera option I get a busy try again later for the video camera i get a system error message. is there anyway I can fix this?
  • demeterzoo Jul 31, 2008
    When I push Camera button ,it says busy try again later
    If I try video Camera it says system Error
    I replaced the Battery
    Cleared all pictures
    Did a master reset
    Problem persists
Try to open the top flip there are four screw covers around your display then take them out whit a little pin then take the screws out whit the t5 screw driver after that hold the caller id down whit your left hand and pull up the top flip whit ur rigth hand or u can use a thiny plastic around the top flip to take it out after u take it out u will see two flex cables on the top one is the end of the camera and the other is the end of the flex cable. pull the flex cable up and desconect it clean the flex cable connector whit alcohol or just blow it then put it back a little hard till u heard the click then try to clean the camera connector there is a little brown plastic on the top of the camera connector pull it up and open it like a door after u clean it put it back and close it then put the side keys back if they were moved then the top flip, screws, and screw covers. if the problem still u have to buy the lcd display but the lcd is too expensive it would be better to buy another v3
Posted on Jul 17, 2007
SOURCE:
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Razr v3 camera
the firmware needs to be reflash on the phone
Aug 17, 2008 | Motorola Mobility RAZR V3
Cant take pictures
have you tryed to turn bluetooth off and everything else off than it mite work if not take it to a shop and they will sort it out
Feb 21, 2008 | Motorola Mobility RAZR V3
Camera does not function. When I push camera button screen says Busy, try again later. If I try the vidio function it says System error, please try again
have the phone's firmware flash and updated and this will correct the issue, this can be done by taking it to a mobile service center or professional technician close to you.
Sep 05, 2007 | Motorola Mobility RAZR V3
Motorola RazorV3 Camera Error
hi there, your camera is faulty and needs to be replaced or it could be a problem with the phone. I suspect the camera once everything else is working o.k. You need 2 take your phone to the nearest service technician to get it replaced. Replacing the camera is fairly easy from my experience as a repair tech. Sam !
Jul 10, 2007 | Motorola Mobility RAZR V3
Camera
Well, it sounds like you need to get it checked out. I'd suggest Radio Shack or Best Buy. There should still be a warranty on it.
May 25, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
203 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
