Question about Bunn 10 Cup Home Coffee Brewer
Bunn is not heating the water
Really need a schematic of the circuits and the expected voltage at various points in the circuit. The off/on main switch is receiving 122 volts.
My bunn coffer maker is the one that keeps water hot all the time.
I was going away and shut my coffee maker off. 'When I came home I then had to start over like when it was new. I follow the directions and the ater never heated up.
Posted on Oct 29, 2013
  • 189 Answers
SOURCE: Bunn coffee maker keeps tripping circuit breaker
This is usually an electrical problem with your brewer. If you will get the model and date code located on the bottom of the brewer and contact Customer Service, you machine can either be replaced at no cost if under 3 years old or if over 3 years old, at a reduced cost.
Posted on May 19, 2010
  • 59 Answers
SOURCE: Bunn keeps blowing the circuit when pulled in
If the circuit resets with the coffee maker unplugged, the coffee maker is at fault. There is a defective part in the unit that is shorted causing an overload in the circuit. You will have to isolate the bad circuit and replace or replace the coffee maker.
Posted on Oct 30, 2009
  • 21 Answers
SOURCE: keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Posted on Jan 07, 2010
  • 189 Answers
SOURCE: GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
  • 189 Answers
SOURCE: Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Posted on Jul 01, 2010
What does bmc mean and what is it for on 1 2001 buick lesabre
BCM - body control module a computer that controls functions on your vehicle . A BCM controls light's , power door lock's , anti-theft system control , Remote keyless entry , headlamps . On your vehicle three modules make up the body control system .
The body control system consists of the following 3 modules:
• The dash integration module (DIM)
• The instrument panel integration module (IPM)
• The rear integration module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line; many control signals are implemented by Class 2 messages.
Dash Integration Module (DIM)
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Control of headlights and exterior lamps
• Horn relay control
• Interior lamps incandescent dimming
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
• Steering wheel controls
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 4 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Ignition 1 voltage
• Ignition 3 voltage
• Off/Run/Crank voltage
Rear Integration Module (RIM)
The RIM is wired to the class 2 serial data line. The various RIM input and output circuits are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• The ajar switch and tamper switch inputs from the rear compartment lid
• The automatic level control
• The cigar lighter relay control
• The fuel door lock and release control
• The heated seat controls
• The park brake relay control
• The rear compartment lid release controls
• The rear defogger relay control
• The retained accessory power (RAP) relay control
• The reverse lamp relay control
• The various controls for the interior lamps
Mar 21, 2017 | Buick LeSabre Cars & Trucks
Vp17-3 bunn o matic will not brew no water will come out if i wait about 15-20 mins it will start spitting out some water like 1/4 full! The heating elements are working on all 3 burners
You have 2 water valves on that coffee maker a water inlet and a dispense valve the warmers are only heat plates the element is inside tank Bunn has a great site for manuals it's a free download
Nov 13, 2016 | Electrical Supplies
Why is 6kg Electrolux Dryer EDV605 not heating
No heat can be several things, first check the voltage to the dryer.
You need 240 volts ac for it to heat. Just because it tumbles isn't proof of the correct line voltage. The heating element could be open, the high temperature fuse could be open. door switch could be bad, heat relay on main board could be bad. If you have a meter there is a schematic or wiring diagram in the dryer somewhere. Make sure you UNPLUG the dryer before taking it apart. Use a meter to check heating circuits. If you do not know how to check continuity, you will need an appliance repairman.
Sep 01, 2014 | Dryers
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
After a afternoon soaking down pour I rode my 2005 Road Kind to the local watering hole. When I came out here's what happened. When the ignition switch is turned to ignition I have no lights and no neutral...
Not necessarily. Sometimes when using a volt meter, a circuit can play a trick on you. Let's take a points type ignition system on the points side of the coil. When the points are open, you'll read battery voltage. When the points are closed, you'll read no voltage. The reason, the voltage will take the path of least resistance and todays modern meters are built with a high impedance so as on to load down a circuit. If it were a low impedance meter, when you touched the circuit, the meter would draw too much current and cause small electronic devices within the circuit to burn up. So, you meter may have been deceiving you.
Now, if you're going to test voltage like that, do it at the battery. Go across your battery with the meter. red to positive, black to neg. With the swith off, you'll read battery voltage at the switch. When you turn the switch on, you will read zero right there. I'd go to the fuse panel and check the voltage on the main circuit breaker. Matter of fact, when you turn the switch on, you should be able to hear and feel the main breaker break the circuit. Usually makes a slight "ping" sound and then resets after about two minutes or so. If the short has not been corrected, it'll simply trip again.
Check all your fuses, they probably will not be blown. This is telling your that it's something that is on the main circuit breaker that is not fuse protected. Now, what that might be, I have no idea as I don't have a schematic for your bike. If you have a light bar on your bike that runs directly off the output of the main breaker, this could be the culprit. It's something that runs directly off the main breaker not through a fuse. You'll just have to look and try to find a schematic.
Good Luck
Steve
Aug 09, 2010 | Harley Davidson FLHR-FLHRI Road king...
Keeps tripping circuit breakers bunn NHb
Hello
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Front panel audio connection to the asus motherboard
hokuwho,
you seem to have found what i seek. im looking for a schematic for my dell latitude d600 to determine which pins of the 9 or so pin battery connection on the mother board require which voltages and or resistances to both supply the 11.1v battery voltage to run the computer, and the other signals voltages resistances etc from the two circuit borads inside the battery case that tell the computer to use the perfectly good fully charged li battery cells or not depending on number of charge cycles. my batttery stopped putting the 11.1 v, it still has alive and well inside, out to the computer mobo, and has stopped charging, or so the computer says, eventhough its fully charged, and yet will not run the computer. i ordered another battery and know why dell in thier infinite though misguided wisdom decided to prematurely kill the good batteries to avoid possible overheating and exploding. but i want for my own knowledge to determine how they are killing the output and possibly design my own circuit that does what they actually needed and meant to do, rather than have the number of charge cycles rule. id just detect battery temperature and ability to charge, and eliminate any counting of charge cycles which is useless, and results in killing perfectly good batteries for no reason. do you know what numberds i actually need to find a schematic. each time i attempt to search with the computer model number, i find schematics of other mfgrs completely different equipment with d600 in the model number, or rar files i cant open, and usually with added notes that downloading this file can harm my computer.
i have always built my own desk tops and fear no electronic circuit but software and file suffixes and wanings of damage to my computer and various types of files apparantly engineered only to confound and confuse give me a little trouble. i started in electronics at a time when each simple circuit stage was built around a single huge glass tube the size of a body builders forearm. and now im working on entire computers with less surface area than one of those tubes. but back when those tubes ruled, manufacturers were trying to build the best longest lasting curcuits they could and drew schematics that actually were intended to be capable of being read by any good tech, and were easy to find with model number, of the equipment. given a schematic i can repair most anything but i cannot find the schematic. but current circuits are desigend to purposely fail for no reason that makes sense so the manufacturer can sell more to replace them, and schematic are well disguised not only in the way thier drawn and marked but even where they are located. ive learned to read nearly all schematics and interpret any schematic symbol, but locating schematics online and getting them to my computer, is difficult for me, eventhough i have desigened and built my own electronic circuits my self all my life.
Nov 15, 2008 | Computers & Internet
We have a Bunn coffee maker manufactured in 2006. Any time we try to use it, it blows a fuse
You didn't mention which fuse it was that blew; I assume you mean a house fuse, not the Bunn's.
Since you mention a fuse rather than a circuit breaker, again, I assume this is the screw-in type that must be replaced each time it fails.
Check your Bunn for the rated power consumption; it should be shown somewhere on the machine and is likely somewhere between 1000 and 2000 watts.  You need to find how much current the machine is drawing.
Divide the given wattage by your line voltage which is probably (if in the US) ~120 Volts. For example: (from the Bunn) 1200 Watts/120 volts = 10 Amperes
That means that when the Bunn is heating water, it will need 10 amps just for itself.  If, for example, you have a microwave oven using that same fuse that has a rating of 1000 watts power to cook with, it will actually draw ~ 1400-1500 watts from the wall plug.  Again, 1500 Watts/120 volts = 12.5 Amperes
Now we have a total of 22 1/2 amps of current if both are operating at the same time or if any other appliance such as a toaster (also draws a bunch) is being used, you will most likely blow a 20 amp fuse if not instantly, perhaps after a few minutes.
Fuses are designed to blow in a few milliseconds if hugely overloaded or to be patient for a minute or two if the over-current is mild; say 21 amperes.
Over-fusing may be dangerous since the fuse rating is related to the gauge of wiring in the circuit it protects. This means that you need to move the Bunn to a different circuit so you don't accidentally exceed the fuse rating with two high-powered appliances if turned on together.
Sep 28, 2008 | Bunn BT10B Coffee Maker
Coffee pot
I am having the identical probem, I plug it in, it starts to heat, but no brewing. I have removed the lid and the water pan underneath, and looked into the opening. When heating, the voltage on the main heater is 110 volts. It stars to steam, then the unit switches off.I think that for some reason,it's not allowing the temp. to rise to the boiling point. Anybody have any ideas? I'll check on that one way valve in the meantime.
May 30, 2007 | Bunn VPR Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
576 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
