Question about Frigidaire Washing Machines
Screaming noise during last spin cycle
Suddenly developed a scream during last spin cycle. It is a combo drier and washer. It has been walking around.
  • Frigidaire Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 19, 2013
COXY
  • 76 Answers
SOURCE: loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Posted on Oct 18, 2007
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
fredcause
  • 51 Answers
SOURCE: loud screaming noise while on spin cycle
bad belt or the tansmission is dry
Posted on Dec 08, 2008
FAV6800AWDIY
  • 526 Answers
SOURCE: SPIN CYCLE -
You need to confirm the Model number of your machine. Is it a FAV6800A or FAV9800A? If so what are the first two digits of your serial number of the machine.
That info can be found here...see pic.
If it's one of the above machine model types supported in this forum you may have Clutch One-Way Roller clutches bearing seized and or Outer Tub Bearings seized.
Both issues cand be handled by a DIY'er with very basic mech. skill sets and some direction if you can deal with the down time........Rich
Posted on May 21, 2010
  • 6277 Answers
SOURCE: My Washer is making a
Sorry but that sounds like either the motor bearings or the drum bearings. Whichever it is requires a service engineer I suspect ;-0(
Sorry we cannot do anything remotely.
Good luck,
John C
Posted on Mar 16, 2011
My Washer is making a terrible noise when it is running. At first it was during the initial filling and now it is alrost screaming when the tub is spinning.
Good luck,
John C
Mar 16, 2011 | Fisher and Paykel Washing Machines
My washing machine is making a loud screaming noise..it's still washing my clothes but when it's on the spin cycle it's almost unbareable.
As the washing machine is making a loud noise I think the first thing I would request you to do is lift up the washer from the front, remove the belt and check the pump by rotating the pump pulley manually. If does not move freely then replace the pump.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Estate ETW4400VQ Top Load Washer
Our IWL12 is making a screaming sound when filling
May just be the sound of the water running thru valve. try adjusting the tap and see if it changes the noise
Jun 29, 2009 | Fisher and Paykel IWL12 Top Load Washer
High pitched noise when spinning or slowing down(cat screaming)
Sounds like you have bad bearings. I suggest you get it fixed before it creates further issues.
Feb 26, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washer
Belt could be worn and screaming
Sep 01, 2008 | Washing Machines
Loud screaming sound during spin cycle
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
416 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
