Question about Whirlpool Duet GHW9150P Front Load Washer
How do you change out inlet screens on whirlpool duet washer
  • Whirlpool Master
  • 17,130 Answers
Check this link: Inlet
Posted on Jan 19, 2013
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
quatlew
  • 139 Answers
SOURCE: Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Posted on Mar 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washer duet is flashing.
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Posted on Sep 30, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
How do I fix F20 code
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
Whirlpool washer duet
The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting a F20 code?
“F20” on display
water supply)
Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
