Question about Datacard Group 150iDesktop Card Personalization System
Datacard 150i transport error
When i turn on my printer it show message said transport error, and sometimes when i try to print card the computer shows message that stepper error.
    New Friend:
Hi If you Tel me the Serial Number of you Machine I probably will be able to help
Posted on Mar 04, 2013
  • James
    James Jun 27, 2016
    Hey Olivert! Just wondering if you could kindly help me out I also have this issue :(
Datacard 150i repair new york city
im looking for a datacard 150i repaired. contact me if you can do the job. thank you michaelwilliams175@ymail.com
Apr 30, 2014 | Office Equipment & Supplies
How do i get a personal support tech for datacard 150i?
I have a problem at work editing the project properties
From the menu bar, select Edit and then Production Form Properties. The Edit Production Form Properties dialog box opens.
data source for select OLE DB provider and source
when Click on the Choose button this message appears error occurred the selection or configuration of adata source
Oct 19, 2010 | Computers & Internet
My datacard sp35 will only print in yellow. What
Do you get any errors?
1 st unplug and plug in to reset power
2nd replace print ribbon with new one, could be bad ribbon or bad RFID tag on the ribbon
3rd try printing a different card
if still not working i would recommend sending in for service.
Contact MidWestIdSolutions.com for more info.
Jan 06, 2010 | Datacard SP35 Plus Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Datacard SP25 only printing half of ID Card
it sounds like a driver error try to reinstall the software
Jul 08, 2009 | Datacard SP25 Printer
Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Nov 25, 2008 | Datacard SP35 Printer
Want to solve my problem
Hi Supermarco:
You are experiencing a common problem whit card printers, usually it happens when the printer needs maintenance. Two things might be producing your problem:
It could be the rollers, may be they are dusty and the card slips, that produces the error message you are experiencing. To solve it I recommend you to clean the rollers using a lint free cloth moistened with isopropyl alcohol. You can press the cloth against roller and move it turning the blue knob located at printers left. I also recommend you to run a cleaning card to the printer as specified on users guide (every ribbon replacement), that will also help you.
Another possible cause of your problem is a blocked by dust sensor. Datacard printers sensors rarely broke, when they produce problems is always due to dust. You can buy a compressed air can and spay with air all the interior of printer, just don’t forget to remove the ribbon and cleaner roller first. In that way dust accumulated on sensors will be removed and your printer will work properly again. I recommend you to operate your printer in a dust free environment, this kind of printer is very sensible to dust and debris. If you still have problem don’t hesitate to ask.
Regards
Oct 17, 2008 | Datacard Group Office Equipment & Supplies
Datacard Group 150iDesktop Card Personalization System Logo
397 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
