Question about E-Machines eMachines Desktop PC
My monitor goes to sleep mode at startup & can't access safe mode
My old emachines T2542 has been acting up on me. When I turn the computer on the monitor (HP Pavilion f1903) says the monitor will go to sleep mode and the blue led turns amber and it is in the sleep mode. I hit F8 twice every 2 seconds but cannot access the boot menu. I tried booting it with the original restore cd's and an original XP OS CD and nothing happened. All the connections seems fine, nothing loose. I unpowered it still no luck. The monitor works with other computers just fine. I did not installed a new mobo or video card.
Is it a bad sector? a bad v-drive? what could it be?? I cannot access to anything. I've been thinking to grab the slave hd (where my docs are) and connect to another pc to transfer the files and rebuild it. However don't know how I am going to re-install the drives and OS XP home SVP 3. I have only xp svp 1 and cannot even access the screens to format the hd. Could someone please explain step by step what to do?
If needed I can provide more information as well.
Thank you very much in advance. Your time is appreciated!
Kerem
  • shazzerham Apr 13, 2009
    My computer beeps when I switch in on and the monitor goes to sleep without even turning on properly. I have updated my security against viruses before this occured and so cannot understand why this is happening.
    Thanks for your time
    Shaz
  • 41 Answers
Turn the computer off, open the case and remove the RAM. Does the computer beep when you turn it on with no RAM? If not, your motherboard is dead.
If your computer beeps, turn it off again and try putting one stick of RAM in. If the computer doesn't turn on normally, try the other stick of RAM.
Also, try taking out the video card and putting it back in.
Good luck,
Jason
Posted on Jan 25, 2009
Screen on my desk top monitor says its going into sleep mode cannot access safe mode monitor screen wont stay on long enough to do or see if anything works....,,, my pc is an hp a6500f , i replaced the...
Try using a different monitor or use that monitor on a different computer to see if the monitor is bad. It shouldn't have anything to do with your CMOS battery. I'd check to make sure the monitor itself is good before I go tearing my computer apart. Let me know how it goes and maybe we can get it figured out.
Aug 03, 2010 | E-Machines eMachines Desktop PC
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Need to access intel graphics application
1. Turn on the computer.
2. Access the safe mode screen. To do this tap on the F8 key after the logo goes away on the screen until the safe mode menu appears. Select VGA mode.
3. This will boot into 640 x 480 resolution, everything will be very big. Now you can go into the properties and select a mode that your monitor can handle.
4. Finally, please rate this solution as fixya as I have answered your question completely with the information you gave me. Thanks! :c)
Jan 25, 2009 | E-Machines eMachines Desktop PC
Monitor goes into Sleep Mode immediatly upon turning on computer
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Emachine sleep mode
Try going into your cmos settings at system boot (usually hitting delete or F keys, funtion keys as your computer first turns on). Check to to see the boot sequence and look for sleep mode settings. If there isnt an option there, boot your system in safe mode and check through your windows settings for sleep mode settings.
Dec 18, 2008 | E-Machines emachines (emachinees) CD-ROM...
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Aug 19, 2008 | Princeton Digital VL173 Monitor
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Desktop PC Logo
1,046 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
