Wiring diagram that shows proper hook up from fuel pump to float and from pump to plate that goes to wiring harness outside of tank
SOURCE: firing order for 1997 jeep cherokee straight 6 cyl.
153624 On cap #1 is two towers clockwise from right side hold-down screw, #1 is front cyl on engine. Firing order is clockwise.
SOURCE: 1996 f150 fuel pump
Hello;
You may have a break in the wire inside the tank to the fuel pump. I have seen the wires disconnect as the pump is installed.
Rich
RPM Northwest
SOURCE: 2001 jeep cherokee sport 6 cyl 4 wdr cranks want start
If the data link is not talking to the computer check your ground at the computer and at the data link connector to see if the computer is even alive ground pin 3 on DLC with the key off then turn key to the run position if it flashes the check engine codes record them, if no engine light, does the engine light come on when you turn the key on then go off? if not, check fuses if not check power for pin on computer, if it has power you have a bad computer. But TEST THE GROUNDS IT IS THE BIGGEST FAILURE For these rigs or any manufacture. check that you have power also at the DLC too. if not you need a digital ohm meter and a subscription to http:///.www.alldatadiy.com and start reading the campaigns on that vechile for computer and trouble tree for dead DLC and computer. I don't have that subscription or I could tell you more where to look, if you need anymore help let me know. Also if the crank sensor could cause it not to run the fuel pump but so can the cam sensor. You need to find out if the computer gets it's pulse for the pump at the computer if it does then you need to test them both. There are three wires a ground a colored power wire and a wire to go to the computer you can test these sensors with a meter to see if there is a pulse to each. sometimes the fuel pump gets it's signal from the coil pack so it's important to have the subscription, you can do a search for each item and test them as needed and has a wiring diagram.
SOURCE: 1995 Jeep Cherokee Country straight 6 cyl 4.0L: I
First of all, the fuel pump is generally located in the fuel tank, not always though. Yours probably is, in did not research it. The fuel electric fuel pump turns on only when the ignition key switch is turned to the start position and then left on. A series of one or two relays along with a pressure monitor in the fuel rail delivery system may or not cycle it on and off depending on design. Enough of that. I suggest that you remove the spark plugs to see if they are oil/heavy cabon deposits.If so, professional attention is reguired. One more thing you could try is replacing the spark plug wires. the may be old/worn out/damage. This would give the engine spark a stronger spark,if worn and also replace the spark plugs.
SOURCE: Steering column diagram needed for 1989 Jeep Cherokee
If you intend to keep the vehicle long term, I would suggest you invest in a Haynes Manual, That is worth its weight in gold, for this and any other project..
Regards,DT
